Internet of Things
Internet of Things
Forum CC3200 ssl demo without loading CA into SFLASH
  • Subscribers 522 subscribers
  • Views 956 views
  • ca
  • security
  • ssl
  • cc3200
I am working on CC3200 and trying to connect to webserver securely (SSL). I have followed the guide lines at
http://processors.wiki.ti.com/index.php/CC32xx_SSL_Demo_Application
and was able to connect to google server successfully.
But now my requirement is not to preload the CA certificate on to SFLASH but still I need to connect to the web server.
Can some one let me know some example or procedure how to connect to webserver without preloading the CA certificate
on to flash since in run time I should be able to connect to the server dynamically.
Thanks in advance
Pavan
    shabaz over 11 years ago +1
    If not preloading, how do you plan to obtain it? Download it from where? Using unsecure HTTP? Which URL? Use some other protocol? If so, which one? Basically, more information is needed from you on the…
    If not preloading, how do you plan to obtain it? Download it from where? Using unsecure HTTP? Which URL? Use some other protocol? If so, which one? Basically, more information is needed from you on the procedure you desire to implement.
    e14 Contributor over 11 years ago in reply to shabaz
    I need to connect to https://apps.lifetechnologies.com
    I have to send user name and password as part of POST in json format and be able to login to the above mentioned site
    Any suggestions on this?
    Thanks in advance
    Pavan
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    Understand that the CA is gathered and saved before access is given to SSL! As to where to store, do you have other storage? Most just use the flash for expedience. Here is another example for Tomcat which sets up a keystore to save the CA's in. http://techtracer.com/2007/09/12/setting-up-ssl-on-tomcat-in-3-easy-steps/ Your problem is can your software support Java and Keystore? If not, they shortcut and store it ahead of time. Sometimes MCU do not have the space or CPU power for the dynamic solution you desire.
    Clem
