Internet of Things
Internet of Things
Forum Internet of Things Sensors
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 522 subscribers
  • Views 2492 views
  • cats
  • sensor
brianchadorourke
brianchadorourke over 11 years ago
Hi.  I'm trying to attach sensors to my cats.  They don't appreciate it as much as I do.  What have y'all done to attach sensors to your pets?
    mcb1 over 11 years ago in reply to Robert Peter Oakes +2
    I've done a bit of work on this. The bigger coil isn't the answer, its improving the Q of the coil which gives the 'gain' you need. Frederick has done a 'cat detector' in his Forget Me Not challenge fvan…
    mcb1 over 11 years ago in reply to Robert Peter Oakes +2 suggested
    Peter The tags use a similar data format, but they are 134KHz rather than 125KHz. Obviously the antenna in the implanted chip is smaller, so therefore its affect on the reader is less, hence why you need…
    mcb1 over 11 years ago in reply to gadget.iom +2
    gadget.iom I was asked to look at making an RFID door using one of these. (keeping with the NZ manufacturer) http://www.transcat.co.nz/products.html It came about through my articles in The Shed magazine…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    RFID Keyfob on a collar to activate the cat flap is a project in the works
    Hardest thing at the moment is getting a big enough coil for the cat to walk through and still sense the keyfob, that and building a flap that works at 20 below in 3 feet of snow (Well maybe a foot)
    0 mcb1 over 11 years ago in reply to Robert Peter Oakes
    fvan
    [CaTS] ForgetMeNot - Week 9: RFID Cat detection and identification
    If your cat's are micro-chipped, its usually in their shoulder, so aiming to have a 'veranda' to rub against is the best location of the coil.
    they will soon learn they need to rub against it and when it beeps, they can get in.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to mcb1
    Was thinking along the same lines with chipped pets.
    Then you don't have a struggle on your hands trying to attach something.
    Our cats were notoriously efficient at removing collars.
    0 mcb1 over 11 years ago in reply to gadget.iom
    gadget.iom
    You also need to have collars that will detach if the cat gets caught.
    Therefore chipping them is the easiest way, plus if they ever get lost they can be returned quickly.
    0 Robert Peter Oakes over 11 years ago in reply to mcb1
    That was also the other avenue I was looking at for the cat flap, the RFID chips embedded in them though are not the same as the cheapo ones from eBay (125Khz or 13Mhz) so will take a little more investigation and hardware to decode the data
    You can but flaps already for this purpose but there expensive ($250 ish) and probably won’t handle the -20 deg temperature and covered with snow requirements of here in Canada
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to Robert Peter Oakes
    There seems to have been a few different frequencies employed in these tags. I found some basic information here: http://en.wikipedia.org/wiki/Microchip_implant_(animal) and here: http://blog.adoptandshop.org/5-things-you-didnt-know-microchips/
    Peter
    Obviously the antenna in the implanted chip is smaller, so therefore its affect on the reader is less, hence why you need a higher Q antenna.
    (They work by shorting the antenna which then detunes the reader antenna)
    There is an Australian supplier who can supply the whole reader or the chips, and Robert Accardi is a great guy to converse with.
    http://www.priority1design.com.au/shopfront/index.php?main_page=product_info&cPath=1&products_id=24
    Texas Instruments has these
    http://www.ti.com/tool/mrd2evm
    They also have some IC's that are -40 degC and remote antenna options.
    http://www.ti.com/lsds/ti/wireless_connectivity/nfc_rfid/products.page#p1507=134.2%20kHz&p199=I/O%20Logic
    OreganRFID have tags, but so does any vet
    http://www.oregonrfid.com/
    I agree the commercial ones can be expensive, but one design had a porch like extension, which may be an idea to keep out the snow.
    http://intl.petsafe.net/en-gb/support/doors/cat/big-cat-small-dog/petporte-smart-flap-microchip-cat-flap
    @fvan
    Looks like this is a very nice feeder.
    https://www.sureflap.com/en-gb/pet-feeder/microchip-pet-feeder
    You guys are making me want to resurect my project ...
  • gadget.iom
    What was your project Mark?
    gadget.iom
    It came about through my articles in The Shed magazine.
    The brief was to try to NOT add the 'extension' and retain the clear aspects of the door.
    They already have a magnetic lock, but the magnets drop off, other cats can get in, etc.
    We wanted it to be able to be made by others, rather than having to buy a particular antenna.
    It might be time to resurrect the project ..... especially since TI has some chips that might be the answer.
    0 dougw over 11 years ago
    I have used the Ti system (134 KHz) with good success. I used antenna coils of various sizes up to about 12 inches to increase range, usually printed on a large PCB, but wire coils worked fine too. They definitely need to be tuned to the correct frequency. These could read a standard tag out to about 8 inches from the antenna, so the pet wouldn't need to go through the antenna - it just would need to be within 8 inches. Incidentally, there are online calculators that will calculate inductance versus geometry of printed coils.
