Internet of Things
Internet of Things
Forum Shelly 1 interference with garage door remote
  • Replies 28 replies
  • Subscribers 513 subscribers
  • Views 6802 views
  • shelly
  • shelly interference
  • garage door
feiticeir0
feiticeir0 over 3 years ago
Hi all.
I'm having a problem with a shelly 1 and my garage door remote.
Recently I've connected my two garage door motors with shellys 1 .
One of them is working perfectly fine with the shelly safe inside the motor housing.
The other one, before the shelly, I was able to open the door with the remote from 10m-15m away (32 ft to 49 ft more or less). With the shelly connected, I'm only able to open the door with the remote, just from 5m (16ft) away.
The motor board is not the same - one is TE120 (working fine) and the other one is ATH10 (the situation described above).
One thing I did noticed was (the one where the distance was reduced), when I was testing, I had the shelly on a 10m (32ft) wire, rolled around an aluminum ladder on the wall and it was working fine. When I reduced the wire (to leave everything nice and tidy on the wall), this started to happen.
I use the same remote for both (different buttons) . I've switched the shellys - could it be a faulty one - but the problem remained.
Could a ferrite filter solve the problem ? Or at least attenuate some interference ?
Thank you
  • feiticeir0
    feiticeir0 over 3 years ago +3
    UPDATE: I new that shelly could be powered by 24v DC, so I've procured a 24v output - the green PINS bottom left of the pictures - and after searching why I wasn't able to power the shelly with 24v (it…
    Jan Cumps over 3 years ago +3
    glad that it's OK now. When I had little children, the family on the other side of the street could not open their garage door when we had the baby-phone on. It took a while to make that connection…
    Jan Cumps over 3 years ago in reply to beacon_dave +3
    The high speed trains between Amsterdam and Antwerp would randomly fail after crossing the Dutch-Belgian border. Software would lock up. Took a while to solve that too ...
  • anniel747
    0 anniel747 over 3 years ago in reply to feiticeir0
    [deleted]
    0 Jan Cumps over 3 years ago
    It took a while to make that connection. They called the service guy multiple times. But because they'd show up the next day during daytime, there was never an issue...
    Until they came home from work the next evening and couldn't get in Slight smile
  • feiticeir0
    0 feiticeir0 over 3 years ago in reply to Jan Cumps
    That's really funny (not for the neighbors Slight smile) . But, like many some other cases, it was sheer luck to find out the cause. It's one of those things that could have lasted for long and never find an answer..
  • beacon_dave
    0 beacon_dave over 3 years ago in reply to feiticeir0
    A bit like the Singapore Metro in 2016 ?
    This Train Has Been Delayed - Uncharted with Hannah Fry
    It’s 2016 and Singapore’s metro system is misbehaving wildly. The rail engineers and company officials are flummoxed. Can data save the day?
    https://www.bbc.co.uk/programmes/m001qw95
    0 Jan Cumps over 3 years ago in reply to beacon_dave
  • beacon_dave
    0 beacon_dave over 3 years ago in reply to Jan Cumps
    Sounds like your baby-phone is causing havoc Slight smile
  • JWx
    0 JWx over 3 years ago in reply to anniel747
    or maybe switching converter changed it's frequency (and generated harmonics) when higher voltage was connected Thinking
  • feiticeir0
    0 feiticeir0 over 3 years ago in reply to beacon_dave
    Loved the podcast ! I already knew Hannah from some documentaries, but know I'm hooked to the podcast. Will listen every episode. Thank you
