Internet of Things
Internet of Things
Forum Hi can anyone rerview my post on esp32 s3 sense camera streaming
  • Replies 8 replies
  • Subscribers 515 subscribers
  • Views 2219 views
  • esp32 s3 sense
manojroy123
manojroy123 over 2 years ago
Hi, can anyone review my project on esp32 s3 sense video streaming.
link:-
www.hackster.io/.../esp32-s3-sense-video-streaming-in-micro-python-0d1486
    shabaz over 2 years ago in reply to manojroy123 +3
    It's not easier, nor is it fair to the original author for them not to be mentioned at all in your write-up. It is not easier because you've got six screenshots for a thing that could have had zero screenshots…
  • misaz
    misaz over 2 years ago +2
    Do you know that you can blog directly at element14? Blog creation is similar to forum post creation. For example, in Internet of Things , you can just click Create a Blog Post big button and create…
    shabaz over 2 years ago in reply to manojroy123 +1
    It's worth explicitly crediting it, providing a link to the original project that it is based on, because it's only slightly implicit currently, because of the link to the zip file of code. That other…
  • misaz
    For example, in  Internet of Things , you can just click Create a Blog Post big button and create post similarly to forum thread:
    I find it hard to follow because of the narrow format at that hackster website. The only worst website for project documentation is probably the Hackaday site (almost every project there is missing important information).
    What's the difference between your project, and this one?  https://wiki.seeedstudio.com/XIAO_ESP32S3_Micropython/
    It's using the same code and hardware it seems.
  • manojroy123
    manojroy123 over 2 years ago in reply to misaz
    I will definitely be exploring it's features.
  • manojroy123
    manojroy123 over 2 years ago in reply to shabaz
    yes, But they haven't documented the content in detail. which can help a novice user to deal with those device quickly. And because I have documented it with my own hand. Next time when I face similar problem, It will help me quickly figure out the solution without any hassle.
    That other project might not be the original one either, since the author there has credited someone else.
    I think the project has _too_ many steps, you've got six screenshots just on obtaining the WiFi SSID and password.
  • manojroy123
    wan't to make it easy for novice user.
    It is not easier because you've got six screenshots for a thing that could have had zero screenshots when there are zero screenshots (and zero information) regarding all the pre-requisites. The text is silent on the need to install Thonny, Python and esptool.
    If you had credited the original author and provided a link to their page, then readers would have seen how to install esptool at least.
    Also it is unusual why, in your write-up, Thonny was used just to launch a command window, and then Thonny was closed. It would have been easier to just open a command window directly, in the way the original project author did.
    There should also be an explanation about why and whether users can use the latest MicroPython firmware or if they have to stick to the (old) firmware in the zip file.
  • colporteur
    colporteur over 1 year ago in reply to manojroy123
    The link indicates the project is intermediate. If designed for novice wouldn't it be classified as Beginner difficultly?
    If you found the article and made the decision to write your own, some credit is warranted for inspiration to the article no matter how much your rewrite.
    I would like to see a define objective. What will be the result after completing the exercise?
    What operating system is supported? Are the screen shots Microsoft Windows 10 or 11?
