Internet of Things
Internet of Things
Forum Can the ESP32 be trusted? Undocumented "backdoor" found in popular microcontroller
  • Replies 9 replies
  • Subscribers 518 subscribers
  • Views 4108 views
  • esp32
  • security
  • bluetooth attacks
  • esp32 backdoor
  • cybersecurity
cstanton
cstanton over 1 year ago
As per https://www.tarlogic.com/news/backdoor-esp32-chip-infect-ot-devices/ :
"At RootedCON, the Tarlogic Innovation team presents research revealing undocumented commands in the ESP32 microchip, present in millions of smart devices with Bluetooth
The cybersecurity company has designed a unique tool to perform security audits of Bluetooth devices on any operating system
Tarlogic Security has detected a backdoor in the ESP32, a microcontroller that enables WiFi and Bluetooth connection and is present in millions of mass-market IoT devices. Exploitation of this backdoor would allow hostile actors to conduct impersonation attacks and permanently infect sensitive devices such as mobile phones, computers, smart locks or medical equipment by bypassing code audit controls."
bluetooth vulnerability
(source: https://x.com/Tarlogic/status/1897584096135581721)
I always suspected that Bluetooth was vulnerable in some manner, but for the ESP32 to have something shady about it is astonishing. If you're interested in cyber security you should check out Tarlogic's github repositories and X feed.
  • embeddedguy
    embeddedguy over 1 year ago in reply to embeddedguy +8
    finally there is a clarification from Espressif today with press release. The key point they said is that these commands cannot be executed remotely over Bletooth or WiFi. Espressif’s Response to Claimed…
  • JWx
    JWx over 1 year ago +7
    After quick examination it seems less severe than hyped: If this is that one: CVE-2025-27840 "Espressif ESP32 chips allow 29 hidden HCI commands, such as 0xFC02 (Write memory)." they have discovered…
  • BigG
    BigG over 1 year ago in reply to embeddedguy +3
    Further details provided on Espressif's developer portal: https://developer.espressif.com/blog/2025/03/esp32-bluetooth-clearing-the-air/
    shabaz over 1 year ago
    Interesting! However, I wonder how much of it will really impact users, for instance, it's unclear how those undocumented commands are run (do they require a malicious firmware update to contain the undocumented commands, in which case the malicious firmware could do anything). I guess we will find out more soon enough since so many of these devices are used. The undocumented commands might be test commands perhaps (e.g. TI and other manufacturer chips have test commands too, but they publish them).
    On another note, for Bluetooth, I've recently started exploring On Semi RSL15.. seems like a nice chip, although it's 0.4 mm pitch which is annoying (not much to do about that, it's the trend with these wireless microcontrollers intended for portable devices).
  • vmate
    vmate over 1 year ago in reply to shabaz
    The RSL15 does look interesting, but their evaluation board is way too expensive. I don't get why companies do this, they aren't making any significant amount of money off of these boards anyways, and essentially lock hobbyists out of their product.
    shabaz over 1 year ago in reply to vmate
    I wasn't happy with the price of it either . Quite a lot of the manufacturers are now charging a lot more than they used to, for their eval boards. If I'm trying a microcontroller then I'll probably want a few boards, and that cost is not insignificant at all.
    I decided it's better instead to spend time preparing the footprint and PCB layout, which I would have to do at some point anyway if I wanted to make use of that chip), so I've started entering it into KiCad. I'm not looking forward to soldering it (I have done 0.4 mm pitch before, but not frequently enough to be good at it).
    I bought enough parts to build three boards (and have hundreds of spare passives left over), for the same cost as one eval board.
  • JWx
    JWx over 1 year ago
    If this is that one: CVE-2025-27840 "Espressif ESP32 chips allow 29 hidden HCI commands, such as 0xFC02 (Write memory)." they have discovered an undocumented API between user code and bluetooth component...
    nvd.nist.gov/.../CVE-2025-27840
    It seems - after quick examination - similar to, for example "WiLinkTm 8.0 Bluetooth® Vendor-Specific HCI Commands" by Texas Instruments, that also contain commands like "HCI_VS_Write_Memory_Block" or "HCI_VS_Read_Memory_Block"
    The main problem here seems to be that it is not documented - but for example direct memory access for radio interface portion of the chip (in many cases beyond control of the programmer) can be really useful for open-source enthusiast/security minded engineers who hate opaque binary firmware blobs
    Whole different story would be if HCI interface would be remotely accessible...
    • Vote Up +7 Vote Down
  • embeddedguy
    Depends what level of PSA certification you have for your chip. For example, the normal esp32 device does not have any certificate. But ESP32-C6 is PSA level 2 certified. Hence more safety for code and data also safety from attacks to corrupt the firmware using OTA etc.
    Sometimes these kinds of news are hyped and what impact it could make to end device is a question to be asked.!
  • embeddedguy
    Espressif’s Response to Claimed Backdoor and Undocumented Commands in ESP32 Bluetooth Stack | Espressif Systems
    • Vote Up +8 Vote Down
  • BigG
  • cstanton
    cstanton over 1 year ago in reply to JWx
    A better than expected outcome!
  • JWx
    JWx over 1 year ago in reply to cstanton
    yes - they are used in many places and mayor security issue would be unfortunate...
