Internet of Things
Internet of Things
Forum Relay interfaces (updated v1)
  • Subscribers 523 subscribers
  • Views 1225 views
pit09
pit09 over 9 years ago
Hey,
I'm trying to develop a couple of IoT devices I wanna hear some recommendations on how to control AC devices for cheap.
I've done some research and I've found some these little devices called Latching Relays. A couple of models that I'm looking at right now are "UC2-4.5SNU" or "EC2-4.5SNU". These are great but I don't find a source to buy them in low quantities.
1- So where can I find any of those models to buy?
For my porpuses, these would a relatively expensive solution. What I like from relays is that you can use them in a somewhat "universal" way, you don't necessarily have to create a new circuit every time you encounter a new appliance, you just have to be a little aware of the potency (watts).
2- Is it possible to create another "universal" solution like I describe with SSRs?
The last thing would be on how to find suppliers for components cus I'm guessing you can find them even cheaper if you talk directly with the supplier.
3-Any suggestions on how to get the contacts from I own?
If any of these questions would be better on other forums or another topic section of Element14, tell me right away.
Thanks and sorry for the trouble.
    jw0752 over 9 years ago +3
    Hi Pablo, Welcome to E-14. Your question is too broad to get much response. If you can do some of the research and ask some specific questions someone might be able to give some suggestions. Include as…
  • pit09
    pit09 over 9 years ago in reply to jw0752 +1
    Thanks for you recommendations I've edited the post now. I believe it's better arranged.
  • c4m4ch0
    c4m4ch0 over 9 years ago +1
    Hello Pablo, 1 - Any particular reason for you choose those models? If not you can choose an equivalent model, for example, here and then use the filter: in Coil Type choose Latching Single Coil/Latching…
    Hi Pablo,
    Welcome to E-14. Your question is too broad to get much response. If you can do some of the research and ask some specific questions someone might be able to give some suggestions. Include as much specific information as you can so we do not waste time guessing.
  • pit09
  • c4m4ch0
    Hello Pablo,
    1 - Any particular reason for you choose those models? If not you can choose an equivalent model, for example, here and then use the filter: in Coil Type choose Latching Single Coil/Latching Dual Coil and so on in the other filters until you find the solution you need. If you want the specific models you mentioned maybe you find them on ebay.
    2 - A SSR is a relay but it is not mechanical so it will not make that "click" sound when it is turned on/off. You can read more about it on Wikipedia and learn more about the differences between SSRs and mechanical relays.
    3 - Buying directly from suppliers is cheaper because you buy them at a large quantity.
    I hope I have helped you.
    dougw over 9 years ago
    SDT-S-105DMR,000 - OEG - TE CONNECTIVITY - General Purpose Relay, SDT-R Series, Power, Non Latching, SPST-NO, 5 VDC, 10 …
    TQ2SA-5V-Z - PANASONIC ELECTRIC WORKS - Signal Relay, DPDT, 5 VDC, 2 A, TQ-SMD Series, SMD, Non Latching | Newark elemen…
    SRRHN-2CN-SL-5VDC - IMO PRECISION CONTROLS - General Purpose Relay, SRRHN Series, Power, Non Latching, DPDT, 5 VDC, 8 A …
  • pit09
    pit09 over 9 years ago in reply to c4m4ch0
    1- Yes. I'm going to use these for IoT purposes so I need the lowest power consumption possible, with latching relays, I just need to power it the instant when I'm doing the toggling.
    2- Yes, I'm aware. I just don't know if for my purpose I can find an SSR that I can change the latching relay with for even cheaper.
