Internet of Things
Internet of Things
Documents Creating my first Raspberry Pi 2 case
  • Date Created: 17 Feb 2015 11:06 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 8:20 AM
  • Views 1351 views
  • Comments 5 comments
After I got my first Raspberry Pi 2, which was just 2 hours ago, the first thing that struck my mind was - "I need a cool looking case for this beauty". Since all beauties need elegant clothing, RPi 2 needs an elegant covering. Here are a few materials I am considering to build it (I want to built it myself):
1. Cardboard -
          Pros - easy to cut and modify with simple scissors and light weight.
          Cons- Fragile, no finesse, low on aesthetics
2. Frostglass -
          Pros - High on finesse and aesthetics
          Cons - Have to get it custom made, dunno from where.
Add more please.
  • raspberry
  • pi
  • raspberry_pi
  • cover
  • cases
  • gadget.iom
    gadget.iom over 11 years ago +2
    How about wood.
    mcb1 over 11 years ago in reply to gadget.iom +1
    Back when I was young, wood was probably the only option. It seemed to do us very well. (of course we didn't need it for this type of use) The design you have shown looks very easy to make from lightweight…
  • bwelsby
    bwelsby over 11 years ago in reply to mcb1 +1
    Indeed before I had a 3D printer I used basewood and balsa wood, very easy to cut with a craft knife, glue sand and paint or cover with materials . I used to build and fly model aircraft many years ago…
  • gadget.iom
    How about wood.
    The design you have shown looks very easy to make from lightweight plywood, and joinen together.
    Simple handtools and some careful cutting should achieve a result.
    Cheers
    Cheers
    e14 Contributor over 11 years ago in reply to mcb1
    Thank you! I'll try this and share the result.
  • bwelsby
    Indeed before I had a 3D printer I used basewood and balsa wood, very easy to cut with a craft knife, glue sand and paint or cover with materials .  I used to build and fly model aircraft many years ago, so used similar construction methods.
    I have also used cardboard, print design on paper, glue paper to stiff cardboard, cut and glue. This can then be covered in a variety of materials, fabric, sticky back plastic, leather etc.
