Open Source Hardware
Blog Copper Clad Prototyping Tools
  • Author Author: shabaz
  • Date Created: 30 Aug 2021 3:17 PM Date Created
  • Views 6713 views
  • Likes 15 likes
  • Comments 19 comments
  • pcb making
  • engraver
  • copper islands
shabaz
shabaz
30 Aug 2021
Following on from a Project14 discussion DIY 100kHz VCO - Build & Test  on copper-clad board techniques for prototyping, I was curious to know how I could improve my current method of using a craft knife to cut channels for creating isolated pads and islands on the boards. navadeepganeshu  suggested using a Perspex cutter, which I have yet to try. I also attempted to use a scriber with a ground-out channel.
I posed the question on a DIY group channel I'm part of with a few old school friends. They suggested I try an electric engraver, or a 'scorper' or 'graver' tool (these tools are used by jewellers for cutting lines and channels in metal).
So, I gave it a shot, using the tools below.
I was really surprised at the quality of the engraver - it was under $20, and seems well made. I don't know if it will last, my main concern was that the grub screws that hold the shaft of the cutter are quite small and I didn't want to over-tighten them in case the screw thread gets torn. Maybe I'm over-worrying, but I will try to find slightly longer grub screws. Aside from that, it all seems like a very neat tool.
However I think I may end up using the second tool, the scorper, a lot more, simply because it won't generate dust as the engraver will.
The 4-minute video below shows the tools in use.
Any other suggestions or ways to improve these techniques would be great to hear!
  • navadeepganeshu
    navadeepganeshu over 5 years ago
    Get the wolverine power to make tarces/cuts on copper clad board perfectly image
    Those cuts with chisel type scorper tool look really neat and would be suitable for small SMD packages. Satisfying to watch as you slide through with butter smoothness,......
  • navadeepganeshu
  • navadeepganeshu
    navadeepganeshu over 5 years ago in reply to navadeepganeshu
       Ultimate clad board prototyping tool
    Ultimate PCB prototyping tool
    • Vote Up +5 Vote Down
