Open Source Hardware
Blog Discrete difference amplifier - AC analysis: gain and bandwidth
  • Date Created: 14 Jul 2026 6:26 PM Date Created
  • Views 577 views
  • Comments 13 comments
  • simple_dcr
14 Jul 2026
This is the AC gain and BW analysis of the difference amplifier module that shabaz designed for a Direct Conversion Receiver.
I'm searching for these points:
  • gain at 1 kHz (approx. mid of bandwidth)
  • -3 dB frequencies
I use Vrms values in the post - common for audio circuits. When measuring one of the differential channels, I tie the other to ground.
Specs:
  • Gain: ~10 dB
  • Bandwidth (-3 dB): ~30 Hz to 40 kHz (approximate)
Measurements:
IN1: gain (1 kHz): 9.2 dB, bw (-3 dB): 30 Hz - 80 kHz
IN2: gain (1 kHz): 9.3 dB, bw (-3 dB): 30 Hz - 80 kHz
 shabaz published the KiCad project on GitHub, including simulation. You could load it into KiCad and check if the small signal simulation and my measurements match ...
For all blog posts in this series, click here
spreadsheet: differenceamp.zip
    Jan Cumps 4 months ago
    For the next blog, I plan to
    • show some internal signals
    • test how the circuit behaves when there is an identical signal on both inputs (desired/theoretical result: no output signal)
    • go into the design, maybe based on Art of Electronics:
    Jan Cumps 4 months ago in reply to Jan Cumps
    Testing common mode rejection. Same signal to + and - input, then measure if the output is "nothing".
