Open Source Hardware
Blog NodeMCU enclosure & prototyping set
  • Author Author: hwhardsoft
  • Date Created: 9 Jan 2018 6:43 AM Date Created
  • Views 2298 views
  • Comments 5 comments
  • din rail
  • control cabinet
  • esp8266
  • cap rail
  • nodemcu
  • cabinet
hwhardsoft
hwhardsoft
9 Jan 2018
Hi,
I want to introduce a new cap rail enlosure set for NodeMCU V2 Amica modules (ESP8266-E12). The heart is an additional pcb with integrated voltage regulator and breadboard. It fits together with the NodeMCU in a 3 module DIN rail enclosure:
Overview:
  • milled 3 module DIN rail enclosure
  • transparent lid in the top for displays, leds ....
  • pcb with socket to plug a NodeMCU V2 (Amica)
  • optional integrated voltage regulator (input voltage 9..35V via 2 way terminal block)
  • breadboard / proto board for own circuits
  • 2x 15 pole female pin header
  • all GPIO pins are marked and placed beside the breadboard area
  • 2x 3 way terminal blocks to connect external components to the breadboard
    genebren over 8 years ago
    Hartmut,
    What a nice little package! Do you have a plan for these modules?  If so, I look forward to hearing more about you plans.
    Gene
    Hartmut,
    Gene
  • hwhardsoft
    hwhardsoft over 8 years ago in reply to genebren
    Dear Gene,
    What do you mean exactely with "plan" ?
    BR
    Hartmut
