Open Source Hardware
Forum Archaeology Resistivity Meter
  • Replies 332 replies
  • Subscribers 332 subscribers
  • Views 56332 views
  • armp
  • archaeology resistivity meter
kltm
kltm over 6 years ago
Hi I'm looking for ideas on an update to a resistivity meter for archaeology. The only published designs for diy were in 2 magazines. One was published in 1997 and the other in 2003. I have copies of both articles available. The reason behind this is the current high cost of available equipment, usually well beyond the reach of most archaeological groups. I've attached a basic block diagram. In the first magazine article the meter is very basic. It relied on the operators to write down the reading given as the survey was taken. Given that a normal survey grid is 20m x 20m and 1 reading is taken on every sq mtr there would be 400 readings to write down and then input into a program used to interpret the results. The later article is really an update to the first where a PIC has been added to record the readings. This again is prone to error, because eadings are taken manually by pressing a button.
I'm sure given the advances in electronics there must be better ways.
  • kltm
    kltm over 6 years ago in reply to michaelkellett +8
    Hi Michael This all sounds very interesting and encouraging. I see you have found the original article, the update is also on slideshare somewhere. I haven’t really thought much about cost, but as you…
    michaelkellett over 6 years ago in reply to shabaz +7
    I can't live with that - I have to have symmetry The problem is that the Howland current pump doesn't constrain the voltage on the load at all when perfectly balanced - and my LTSpice model is unrealistically…
    michaelkellett over 6 years ago in reply to michaelkellett +7
    AS promised - now for the phase sensitive detector. I couldn't easily model this in LTSpice, which is no great surprise because it needs multiplication and square roots. I used Simulink in MATLAB - which…
    michaelkellett over 6 years ago in reply to kltm
    I posted about the batteries I bought from Amazon in post 190 of this thread and Shabaz posted about the holders he bought from Aliexpress in 196.
    Neither post (nor the Aliexpress web site) has dimensions.
    The battery design is a Sony thing, so far I have not found a drawing with detailed dimensions.
    The holder Shabaz found is this one:
    https://lilliputdirect.com/index.php?route=product/product&product_id=824
    Lots on Ebay, including chargers and dual socket things at pretty low prices.
    I searched for np f970 adapter
    If you don't bother with the official mounting but dropped it (the battery) into a suitably shaped hole with to prongs at the bottom you could have a lif with thumbscrews to seal it up and hold them in place.
    shabaz over 6 years ago in reply to kltm
    Hi Ken,
    It's a Sony design intended for cameras but many manufacturers produce it, so it is unlikely to go obsolete quickly. It is called Sony NP-F sized, there's a video about it here:
    But any 7.4V LiPo ought to be fine, i.e. it is a decision the constructor can make. Some may already have (say) Canon or Nikon batteries so may prefer to use that. But personally I like the Sony design, it has large circular contacts, which feels more reliable for projects with low-cost battery holders.
    Also, maybe a small piece of foam is needed? since there could be shock or vibration, and double-check the lock on the battery-holder is sufficient or not. I don't have a mechanical background so I don't know what other precautions to take, however it could also be worth mounting the battery holder on some shock-absorbing material too.
  • kltm
    Brilliant, thank you Shabaz and Michael. I knew we had discussed batteries earlier I just wanted to make sure we were still going with them. I will do some work on them.
    Ken
  • davemartin
    davemartin over 6 years ago in reply to michaelkellett
    michaelkellett  wrote:
    Hello Ken and Dave
    Search ARMP on the front page of E14 or in the Open Source Hardware Group.
    This started after the discussion about having our own group.
    Thanks very much Michael, have found and will study then now. Absolutely agree about the handicap of not having a suitable forum (sub) section. I would not have been searching every day and trying to spot topics (and then see if they had changed!).
    Meantime, could I suggest that whenever any any new threads are started, we post a link here so as to alert everyone who is following the main thread?
    cheers/Dave
  • davemartin
    davemartin over 6 years ago in reply to davemartin
    Everyone,
    Further to the discussions on the injection aspect, and the linearity (or otherwise) of the ‘device under test’, I’ve run some tests, and started a separate thread to keep them in one place.
    ARMP Archaeology Resistivity Meter Project - base data
    I've chopped them up to make them slightly more digestible (and easier to post, since this BBS doesn't allow pasting fully-formatted from Word). Part 1 just posted is basic injection data, next section with control plots and alternative stimuli etc. will follow in part 2.
    Dave
    michaelkellett over 6 years ago in reply to davemartin
    Great stuff - it's always nice to see some real data !
    The other (and related good news) is that I've already been working on an enhanced power amplifier that uses 60V rated amplifiers.
    My plan was to use +/- 25V supplies which would give us about 46V pk, and 92V pk-pk so very little short of your test.
    The noise on your test results is better than I had expected - but obviously we shouldn't read too much into a single test with regard to background noise.
    The same amplifier will be able to manage +/- 100mA with reduced supplies (+/- 10V) - this won't be switchable but will require different components at build time.
    I need to to a bit more simulation work but should get the rest of the schematics posted this weekend.
  • davemartin
    Thanks Michael,
    Part 2 will have some background noise plots as well. Hope to get that posted later today.
    cheers/Dave
  • davemartin
    Everyone,
    Part 2 on background data now posted on interference, noise etc.
    https://www.element14.com/community/message/295245/l/re-armp-archaeology-resistivity-meter-project-base-data#295245
    Hope to post part 3 starting to look at excitation waveforms tomorrow if time and work permit.
    Dave
    I forgot about posting reminders here - I posted the almost complete design a couple of hours ago in the Open Source Hardware Group.
  • davemartin
    Everyone,
    I've just posted the next chunk of data, Part 3, at https://www.element14.com/community/message/295289/l/re-armp-archaeology-resistivity-meter-project-base-data#295289  documenting excitation with:
    • Square wave 137Hz
    • Square wave 80Hz
    • Square wave 32Hz
    • Sine wave 137Hz
    • Triangle / symmetric sawtooth 137Hz
    • Trapezoid wave 137Hz
    Analysis (quantitative and qualitative) will follow in part 4 as soon as I have time to finish writing it up.
    Dave
