Passive Components
Passive Components
Forum Unusual Variable Inductor
Join Passive Components to participate - click to join for free!
  • Replies 12 replies
  • Subscribers 111 subscribers
  • Views 4092 views
  • variable_inductor
jw0752
jw0752 over 11 years ago
I was digging through my electronics graveyard and I found this interesting variable inductor. It has a ceramic drum wound with 14 gauge silver alloy wire. I measure a minimum to max range of 1uH to 12uH. As the drum is turned a small idler wheel rolls over the coil as a variable tap changing the amount of the coil that is included in the circuit. I was hoping that someone could tell me more about its original application. The square plates on the frame are 6.2 cm on a side and the length of the body is 9.5 cm. The front main shaft is coupled to the drum with an insulated universal joint. I see a shadow on the ceramic where there was likely a label at one time but it is gone now. If I can get a little more information about it I will put a tag on it so the next time someone runs across it there will not be a mystery.
Thanks John
  • D_Hersey
    D_Hersey over 11 years ago +2 verified
    To me, it looks like a medium-power 'roller inductor.' The gear makes me think it was intended to be operated by a motor. The most likely application was to tune an HF antenna. Yup, HF autotuner is my…
  • D_Hersey
    I think due to its scale that this was used on the transmit side to normalize the load. The application circuit would have been along these lines: Pi-Match | Electronics and Electrical Engineering Tools…
    jw0752 over 11 years ago in reply to shabaz +1
    Hi Shabaz, I was thinking that the operator had to watch a meter and power the motors manually but if I understand you correctly the motors would auto tune the antenna using an algorithm. this is pretty…
  • clem57
    0 clem57 over 11 years ago
    Its a time machine LOL. In miniature of course
  • D_Hersey
    0 D_Hersey over 11 years ago
    To me, it looks like a medium-power 'roller inductor.'  The gear makes me think it was intended to be operated by a motor.  The most likely application was to tune an HF antenna.  Yup, HF autotuner is my guess.  Probably tunes a resonant trap to keep the RF load around 50 ohms as the amp sees it.  I think the ARRL 'Antenna Handbook' or some such may be for you.
    You should consider getting a HAM liscence.  Or 'license' depending upon which side of the pond you are lurking at.
    Are you aware of 'fractal antennas?'  Neat stuff.
    0 jw0752 over 11 years ago in reply to clem57
    Hi Clem, I like your answer and I wish you were correct but Steven Hawkins says sorry no time machines.
    0 jw0752 over 11 years ago in reply to D_Hersey
    Hi Don, I searched "Roller Inductor" on the web and found that you are correct about what it is. I will add this information to my tag on the Roller Inductor. You even explained what the gear on the main shaft was for as I can see that it is not uncommon for these to be motor driven. As far as becoming a HAM radio operator, well we will see. Thanks for the great reply.
    0 shabaz over 11 years ago in reply to jw0752
    Hi John,
    I also agree with Don's assessment. You can see the insides of an ATU at this URL, in action: https://www.youtube.com/watch?v=AnztAIWnSxo
    (it shows motorized variable capacitors instead of variable inductor, but the principle is similar).
    I think this was an early way to do it, but a later method was to use relays to switch in inductors and capacitors, i.e. no need for motors.
    It was fun to watch them in action, there would be a buzzing sound as all the relays clicked in an algorithm (i.e. briefly transmitting while measuring the amount of
    transmitted or reflected signal) until the antenna was best tuned.
    0 jw0752 over 11 years ago in reply to shabaz
    Hi Shabaz,
    I was thinking that the operator had to watch a meter and power the motors manually but if I understand you correctly the motors would auto tune the antenna using an algorithm. this is pretty cool and not what I expected from older technology.
    Hi John,
    Indeed, very cool technology. There may have been manual versions, but the more advanced ones could do it all automatically.
    0 balearicdynamics over 11 years ago
    Hi John,
    I agree with him, as I saw some of these in-action. About the gear - as far as what I saw - maybe a motor for big motorised antennas where the inductor rotates synched with the antenna too. Maybe considered the "ancient" motorised satellite dish image
    A simplified version it an air insulated inductor to tune frequencies on Germanium based radios. This is one of the first radios I have experimented with.
    Enrico
    0 jw0752 over 11 years ago in reply to balearicdynamics
    Hi Erico,
    Thanks for posting the interesting tuning box. I never thought about a tightening helical coil as a variable inductor before but  the physics says it will work.
    0 balearicdynamics over 11 years ago in reply to jw0752
    Hi John,
    this strange "circuit" and the variable capacitor made me crazy too for a lot of time when I discovered this. And the strange is that it worked. I heard for hours incredible transmissions with this primitive radio image
    Enrico
