Passive Components
Passive Components
Forum I want to make a capacitor discharge tool
Join Passive Components to participate - click to join for free!
  • Replies 24 replies
  • Answers 15 answers
  • Subscribers 113 subscribers
  • Views 12174 views
  • passives_featured
  • capacitor_discharge_tool
jw0752
jw0752 over 8 years ago
I want to make a capacitor discharge tool for use in an industrial application where the voltage may be as high as 400 volts and I have no idea what the maximum capacitance may be. I have been weighing the pros and cons of different resistor values. Then I thought, Why not ask some of the best engineers on the planet? If you have some insights for me it would be appreciated.
    mcb1 over 8 years ago +8 suggested
    Sounds like it's for a switch mode power supply. Most of them are 470-1000uF, and to prevent damage you'd want to restrict the current to 1A. R= E/I so 400/1 = 400 ohms. Discharge from here https://www…
    jw0752 over 8 years ago in reply to jc2048 +7 suggested
    Hi Jon, As promised I have run some experiments after returning home. I have taken a 2000 uF 200 Volt capacitor and charged it up. The formula for energy in a capacitor is 1/2 CV^2 which works out to about…
    jw0752 over 8 years ago +7 suggested
    Last Post: I put the unit together this afternoon using the advice and wisdom from my Forum friends. The series resistor was lowered to 330 ohms and wattage increased to 5 Watts. I discharged the 2000…
    0 jw0752 over 8 years ago in reply to michaelkellett
    Hi Michael,
    Vishay has so much depth in their product lines. I did not know that there were pulse rated product available. I always just guessed and used an over rated resistor to address this concern. Of course all the things that I have designed are relatively simple and usually only for my own use so critical engineering isn't a factor.
  • jc2048
    0 jc2048 over 8 years ago in reply to jw0752
    Since we're talking about Vishay parts, an alternative to a resistor that you might experiment with would be a PTC thermistor.
    http://www.vishay.com/docs/29165/ptcel.pdf
  • three-phase
    0 three-phase over 8 years ago in reply to ciorga
    Dielectric absorption also occurs when we carry out high voltage DC tests on motor and generator windings, as when tested to earth, these just act as big capacitors. Our rule is that once discharged, the winding should be  directly shorted and earthed for at least twice the duration of the test time, to ensure that the voltage does not creep back up when the winding is reconnected.
    In practice, we will usually try to carry out all the tests one day and leave the windings shorted to earth overnight and then reconnect the following day.
    Kind regards
    0 jw0752 over 8 years ago in reply to three-phase
    Hi Donald,
    I really appreciate your insights from a field of electronics that I haven't had any experience with. I have found your posts about testing motors and generators very interesting.
