Passive Components
Passive Components
Forum Need to replace resistor 900 ohms / % Tolerance
Join Passive Components to participate - click to join for free!
  • Replies 41 replies
  • Subscribers 108 subscribers
  • Views 11728 views
Alex-andre
Alex-andre over 3 years ago
Hello there,
I need to replace this resistor which appears to be a 900 ohm with a % tolerance. (4 rings = Black / White / Red / Silver or Grey and around 25mm long)
I bought one with almost same features (OHMITE OX102KE Through Hole Resistor, 1K ohm, OX, 1W, ±10%, Axial, 300V) but it doesn't fit, it's far too small compare to the one I need to replace. Do you have any suggestion where to buy or how to replace it ?
I attached a picture below.
Thanks a lot
Aleximage
    jw0752 over 3 years ago in reply to dougw +5
    Hi Doug, I'm doing good. Glad to see so many old friends still around.
    jw0752 over 3 years ago +3
    Based on my experience with this style relay it is highly probable that the resistor is across the Normally Open relay contacts and serves as a soft start to the load. As configured it would current limit…
  • Gough Lui
    Gough Lui over 3 years ago +1
    Do you have any information about the power rating? As long as the power rating of the replacement is the same or greater than the original, it doesn't really matter that it is physically smaller. You…
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to michaelkellett
    Here is the picture of the entire board. It allows to vary the speed (power) of electrical pump. There is a timer attached to it but that on the front panel.
  • Gough Lui
    0 Gough Lui over 3 years ago in reply to Alex-andre
    Hmm. Looks like part of a relay R-C snubber ... I wonder if the capacitor is on the rear-side of the board ... there are probably a range of values that could work. It would be there to avoid the relay contacts from arcing/welding together.
    That being said, michaelkellett is right - you should measure the resistor and see what value it measures at the moment. It certainly looks like it's been hot, but not hot enough to cook to death just yet ...
    - Gough
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to Gough Lui
    Ok, will do, thanks for all the information.
  • Alex-andre
    Rear side nothing special.
    0 shabaz over 3 years ago in reply to Alex-andre
    Maybe it's for switch-on surge protection (i.e. before the motor starts fully spinning, it could be for providing less power to the motor, and then the relay kicks in). In any case, based on no further information, I too would not automatically assume it is faulty, because a bit of discoloration can be normal in such boards.
    0 michaelkellett over 3 years ago in reply to shabaz
    I posted a similar conclusion, but Verint ate it !
    The tracks to the resistor and the relay contacts are quite chunky and augmented by a soldered on wire, so I think the designer expected large currents.
    I agree that the resistor may well be OK.
    Any replacement should be of similar size and surge (or short term overload) capacity.
  • Alex-andre
    yes something I should have mentioned first is that a current surge from wires arc effect have conducted to dysfunction of the box and a strong smell of burn and resistor was hot.
    I think you're wasting an opportunity. If only you could be more detailed, and explain what occurred, and what occurs, then people could help. Things like "dysfunction" just means that it doesn't work in some way, this is not very detailed. It's a big resistor, it is expected to be (at some point) hot.
    People have limited time, and the time is wasted if you don't provide more detail from the start, including what troubleshooting you have done and what happens with the rest of the system to make you believe the fault lies here. My time is up anyway, I have to do other stuff.
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to shabaz
    thx, as I've mentioned at first I'm not an expert so apologize for non expert terminologies used or organized process explanation. Take care
  • robogary
    0 robogary over 3 years ago in reply to Alex-andre
    likely something else downstream either failed or shorted to ground. The resistor may be a victim of another different component failure.
