Passive Components
Passive Components
Forum Need to replace resistor 900 ohms / % Tolerance
Join Passive Components to participate - click to join for free!
  • Replies 41 replies
  • Subscribers 108 subscribers
  • Views 11756 views
Alex-andre
Alex-andre over 3 years ago
Hello there,
I need to replace this resistor which appears to be a 900 ohm with a % tolerance. (4 rings = Black / White / Red / Silver or Grey and around 25mm long)
I bought one with almost same features (OHMITE OX102KE Through Hole Resistor, 1K ohm, OX, 1W, ±10%, Axial, 300V) but it doesn't fit, it's far too small compare to the one I need to replace. Do you have any suggestion where to buy or how to replace it ?
I attached a picture below.
Thanks a lot
Aleximage
    jw0752 over 3 years ago in reply to dougw +5
    Hi Doug, I'm doing good. Glad to see so many old friends still around.
    jw0752 over 3 years ago +3
    Based on my experience with this style relay it is highly probable that the resistor is across the Normally Open relay contacts and serves as a soft start to the load. As configured it would current limit…
  • Gough Lui
    Gough Lui over 3 years ago +1
    Do you have any information about the power rating? As long as the power rating of the replacement is the same or greater than the original, it doesn't really matter that it is physically smaller. You…
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to robogary
    ok thank you
  • robogary
    0 robogary over 3 years ago
    Another easy thing to try is to remove the 3 output wires to the motor , see if the problem goes away. Perhaps the output is grounded.
  • Alex-andre
    ok
  • scottiebabe
    0 scottiebabe over 3 years ago
    Does the front electronic display turn on when power is applied to the unit?
  • Alex-andre
    0 Alex-andre over 3 years ago in reply to scottiebabe
    no, not anymore.
  • robogary
    0 robogary over 3 years ago in reply to Alex-andre
    if the problem goes away after removing the motor leads, use an ohmmeter to check each motor lead to ground. the readings should be well above 10 kohm. Measure ohms between the 3 motor leads, 1-2, 2-3, 1-3 they should be approximately the same. You could also check to see the pump motor shaft is not stuck or frozen.
  • Alex-andre
    ok
  • robogary
    0 robogary over 3 years ago in reply to scottiebabe
    rofl - thats a great question that we all should've asked first
  • scottiebabe
    0 scottiebabe over 3 years ago in reply to Alex-andre
    It is quite likely that power resistor has failed. Though a test with a multimeter is really the best way to know.
    From a cursory glance the control electronics also derive their power supply down stream of that resistor.
    You can try your 1k resistor and see. It might get really hot. Of course leave the motor disconnected. You could wire an incandescent light in series with the power input as safety precaution.
    0 Jan Cumps over 3 years ago in reply to scottiebabe
    It doesn't look defect though. Discolouring isn't uncommon for power resistors that get hot while in duty.
    Definitely.
