Passive Components
Passive Components
Forum Can someone help identifying what this are? I reckon it is an old diod. Need something to replace it with
Join Passive Components to participate - click to join for free!
  • Replies 65 replies
  • Subscribers 105 subscribers
  • Views 10464 views
kardan
kardan over 2 years ago
imageimageimageTUAC TD500-C1 mono amplifier
TUAC TD500-C1 amplifier boardimage
The simple markings on photo does not have the Anode and Cathode marked.
Please reload the page as I have updated the last image.
  • geralds
    geralds over 2 years ago in reply to Ian-Scott +3
    Hi Ian-Scott Just I've rotated it for some readers. Best Regards Gerald ---
  • anniel747
    anniel747 over 2 years ago +2
    Deleted
    shabaz over 2 years ago in reply to anniel747 +2
    Could be.. I thought maybe the color code was brown-yellow-gray, 148, i.e. maybe 1N4148, but I've not seen that before. Anyway, hopefully photo(s) can make it clearer, or some context.
  • Ian-Scott
    0 Ian-Scott over 2 years ago
    I would check all the R33 wirewound resistors as the have  tendancy to fail
    0 Jan Cumps over 2 years ago in reply to Ian-Scott
    There is a name for that. It's "munching" (edit - Muntzing) or something. Named after a USA electronics company owner that would walk down the production line and randomly cut out components.
    If the device still passed the QA, the component was removed from the BOM.
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to Jan Cumps
    They all still work ok. TUAC were always changing their circuit designs. I've got 5 TD150 amp modules that are all different, ranging from a few resistors to number of transistors
  • geralds
    0 geralds over 2 years ago in reply to Ian-Scott
    Hi  Ian-Scott
    Best Regards
    Gerald
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to Ian-Scott
    I have a TD300 amp which is just a TD500 with a pair of output transistors omitted
  • kardan
    0 kardan over 2 years ago in reply to Ian-Scott
    Thank you so much :)
    I will now check what is correct and if something has been changed by someone else
    So it should be a 6.3A T fuse? someone has changed this to 10A T and the other 10A F
  • Ian-Scott
    0 Ian-Scott over 2 years ago in reply to kardan
    Both should be 6.3a TD
  • Ian-Scott
    I would check those smoothing caps on the rectifier boards they would have both been the same and TBH they look well old
  • kardan
    Yes. Thanks, I will get some new components today but not the 330pf. Must order again. Some components have the wrong value on board. so I will try follow it around and check. Where do you find the R33 wirewound resistors?
    0 michaelkellett over 2 years ago in reply to kardan
    Farnell have a good range but if you don't have an account you may prefer Amazon who seem to have lots.
    These would do, they have some that would be a better choice but not on Prime.
    https://www.amazon.co.uk/YOKIVE-Resistors-Resistor-Tolerance-Electronic/dp/B0BNBF8CY6/ref=sr_1_9
    These are 2W and quite small.
    If you plan to drive 4R loads for long periods then you could use 4 in place of each original resistor (2 parallel pairs in series).
    I didn't like the look of the 3W carbon film ones at Amazon but the 5W "cement" ones would be OK if you don't mind waiting.
