Power & Energy
Power & Energy
Blog Possible Lightning Strike - Tree Leaf Post-Analysis
Toptech-Voices
  • Author Author: shabaz
  • Date Created: 31 Jul 2018 4:03 PM Date Created
  • Views 3553 views
  • Comments 17 comments
  • lightning bolt
  • lightning
shabaz
shabaz
31 Jul 2018
The UK has been having really nice (hot) weather recently, although there was a brief rainstorm, and possibly lightning during periods over the last few days.
We have small pear and plum trees, about 15-20 feet high perhaps. Anyway, the leaves looked really strange today : (
I'm not sure, but I'm wondering if lightning caused it. There are large trees from neighbouring properties that are much taller, and close by. There was some scattering of strange leaves in them too, and generally in the same area, i.e. the entire trees do not seem to exhibit the effect, but it is localised. I can't see any burn marks on the ground, but I have not checked the grounds of the neighbouring trees.
Notice the browned leaves:
More close up:
The pears seem disaffected, but the leaves look toasted : (
A plant at the foot of the tree:
A neighbouring tree:
Scattered clumps of browned leaves in a neighbouring tree:
Closeup of the browned leaves in a neighbouring tree:
Has anyone else experienced anything similar? Do the photos above look like lightning damage, or could something else have caused it?
I'd be interested to hear all thoughts.
    DAB over 7 years ago +4
    Looks more like an infestation, not a lightning strike. If lightning hits the tree, you should see a scar on the bark. Typically, the rest of the tree is unaffected, so you would not see the kind of spotty…
    beacon_dave over 7 years ago +3
    If you want to 'compare trees' then if you head North, there is a tree in the ancient forest at Landmark near Aviemore ( https://www.landmarkpark.co.uk/attraction/ancient-forest/ ) that was hit by lightning…
  • fmilburn
    fmilburn over 7 years ago +3
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground. Entire chunks of bark could be blown out. I have not seen leaf damage…
  • fmilburn
    I have lived in areas with lots of lightning and trees that were struck had damage where the strike occurred along the trunk to ground.  Entire chunks of bark could be blown out.  I have not seen leaf damage like that in your photos from lightning but that does not mean it is not possible.  You might check for mites or other small insects under your microscope :-).  Also your local plant nursery may know if it is insects or some kind of wilt.
    Jan Cumps over 7 years ago in reply to fmilburn
    The brown things on the last tree are seeds. On the first tree, it may be lightning.
    A smell test can help. Pull a few leaves and smell if there's a (faint) burn odor.
    The curliness of the leaves together with the discolor can indicate a tree health issue too.
    shabaz over 7 years ago in reply to Jan Cumps
    Hi Jan,
    Ah I should have checked.. It is quite far away, I has a zoom lens but I didn't check the photos I snapped in detail : (
    There is localized brown in the taller trees though (close to where our trees are), I'll try to take a better photo.
