Power & Energy
Power & Energy
Blog The GaN BoosterPack Series: LMG5200 Evaluation Pack and Smart Instrument
  • Date Created: 13 Dec 2016 4:46 PM Date Created
  • Views 3174 views
  • Comments 6 comments
  • boosterpack
  • texas_instruments
  • gan
  • scpi
  • hercules
13 Dec 2016
This series of blogs describes the design of a GaN BoosterPack and its LabVIEW integration.
The LMG5200 is a GaN Half Bridge that can manage 80V and 10A. This BoosterPack allows you to evaluate the performance of the device. You can change its operating parameters via software and via the on-board rotary encoder.
The GaN BoosterPack is designed to be used with a Hercules LaunchPad.
The LaunchPad delivers the complementary signals required to drive the LMG5200 GaN Half Bridge.
The project comes with firmware that allows you to change the driver signals to your needs.
You can change duty cycle, frequency, deadband from LabVIEW or other lab automation software that supports USB and SCPI.
There's stand-alone firmware that changes the duty cycle when you rotate the rotary encoder on the BoosterPack, if you prefer that.
All schematics, PCBs, BOM and source code is attached to the blog posts.
{gallery} GaN BoosterPack
Hercules LaunchPad: proto setup
LabVIEW: test SCPI firmware
LabVIEW: Control software design
Hercules LaunchPad: First tests with a modded LMG5200 evaluation module
GaN BoosterPack: first schematic
GaN BoosterPack: KiCad 3d viewer
LMG5200: Layout Guidelines
GaN BoosterPack: one of the evaluation kit (reference design) PCB layers
GaN BoosterPack: KiCAD view of an internal PCB layer
GaN BoosterPack: Custom KiCAD footprint for LMG5200
GaN BoosterPack: Seeed Studio PCBs
GaN BoosterPack: Device under test
Related Blogs
Hercules LaunchPad and GaN FETs - Part 1: Control Big Power with a Flimsy Mouse Scroll Wheel
Hercules LaunchPad and GaN FETs - Part 2: Make a BoosterPack
Hercules LaunchPad and GaN FETs - Part 3a: BoosterPack Layout - Reference Design
Hercules LaunchPad and GaN FETs - Part 3b: BoosterPack Layout - my version
Hercules LaunchPad and GaN FETs - Side Note A: BoosterPack Layout - Custom KiCad Parts
Hercules LaunchPad and GaN FETs - Side Note B: Look at the PCB
Rotary Encoders - Part 1: Electronics
Checking Out GaN Half-Bridge Power Stage: Texas Instruments LMG5200 - Part 1: Preview
Rotary Encoders - Part 4: Capturing Input on a Texas Instruments Hercules LaunchPad with eQEP
Vintage Turntable repair: Can I fix a Perpetuum Ebner from 1958 - part 4 - Hercules LaunchPad Enhanced PWM try-out
Related Blogs : Smart Instrument with SCPI
Create a Programmable Instrument with SCPI - Part 1: Parser Library
Create a Programmable Instrument with SCPI - Part 2: Serial over USB
Create a Programmable Instrument with SCPI - Part 3: First Conversation *IDN?
Create a Programmable Instrument with SCPI - Part 4: Error Handling by Default
Create a Programmable Instrument with SCPI - Part 5: First Hardware Commands
Create a Programmable Instrument with SCPI - Part 6: LabVIEW Integration
Create a Programmable Instrument with SCPI - Part 7: Talk to Hardware Registers
    Jan Cumps over 9 years ago in reply to Jan Cumps +2
    Oops, maybe a little too over-enthousiast: The right leg of my sophisticated electronic load melted. It was nice to see - happened in just a blink of the eye. The base of that right arm turned red, and…
    DAB over 9 years ago +1
    Nice board work. Looking forward to seeing the board in testing. DAB
    Jan Cumps over 9 years ago in reply to DAB +1
    It's performing ok at the moment, DAB I'm slowly checking how it behaves under load. I haven't put the design under big pressure yet. Currently running a 10.3V 1.2A load with a 14V input. The GaN package…
    Nice board work.
