Power & Energy
Power & Energy
Forum Power Supply Question and Request.
  • Replies 13 replies
  • Answers 5 answers
  • Subscribers 284 subscribers
  • Views 2183 views
  • power regulator
  • power electronics
  • power design
eye-zen
eye-zen over 8 years ago
Hi People - i have a request for the members for assistance.
Brief Background - I build Robots and Drones - both ground based and aerial. My background is programming not physical design....
My request is this:-
A power circuit capable of taking in at least 36v dc and outputting any and or all of the following 3,3v 5v 6v 7.4v 9v 10v 12v -- these are the standqrd voltages required by our robotics platforms.
The input voltage needs to be anywhere from 6v to at least 36v - although higher is ok.
The out[uts would ideally be switchable and selectable so that at least any 3 of those voltages could be output at once - ie 3.3 and 5 and 10 volts out all at once....
I dont know if this is possible or not - thats where you come in ....
If possible i would like a schematic and a BOM to build this..
Please help
Cheers
Al
    jw0752 over 8 years ago +5 suggested
    Hi Al, What you describe is possible, but to build a universal supply will not be as efficient as building to a specification. For a specific application one would need to know the voltage of the source…
  • rachaelp
    rachaelp over 8 years ago in reply to eye-zen +3
    Al French wrote: ahhh and also ltpowercad looks like a windoze program - why doesnt anyone support linux anymore hahaha - virtualbox here we come Tell me about it.... I use Mac/Linux machines and Windows…
    dougw over 8 years ago +1 suggested
    You could try one of the design tools that guide you through complete solutions. Like TI tools: Power supply design for single loads | WEBENCH tools | TI.com SWITCHERPRO SwitcherPro(TM) Switching Power…
    0 jw0752 over 8 years ago
    Hi Al,
    What you describe is possible, but to build a universal supply will not be as efficient as building to a specification. For a specific application one would need to know the voltage of the source of power. The amount of current that the source can deliver would be a limiting factor on the outputs. For example the voltage of your source times the limit of its current will define the wattage of the source. The voltages of your secondary systems times each of their respective currents are the power in watts that is being consumed by your device. The power consumed can't be greater than the power available at the source. You would need to know the different voltages that are needed as well as the current that will be needed for each voltage. There is a big difference between building a 5 volt one amp supply and a 5 volt 10 amp supply. I am not an engineer and so I have found for my own projects that there are a lot of DC to DC converters commercially available at reasonable prices that I integrate into my designs. Most of these converters use switch mode power supply (SMPS) designs and are very efficient. (Some in excess of 90%). this is very important particularly if your device is running from a limited supply such as a battery. Many of these converter modules will take a range of voltages for input and deliver a range of voltages for output. In this way I can input from 4 V to 36 V and get 1.2V to 34 V out. These are called BUCk converters as they reduce the voltage. Here is an example of a BUCK converter:
    http://www.ebay.com/itm/DC-DC-CC-CV-Buck-Converter-Step-down-7-40V-to-0-8-35V-12A-Power-Supply-Module-/272614244686?hash=item3f7913414e:g:p7QAAOSwuLZY39YW
    You can see where a series of these converters could be tied into a voltage source and each be tuned to a specific output voltage. As long as your device doesn't try to draw more current than the device is capable of they seem to work very well. Of course for the money they are great for non-critical applications. I would not recommend them for any critical or medical application.
    Rather than continue to ramble I will send the conversation back to you and we can expand the discussion if this is what you are interested in.
    I call my approach to design the Borg approach as I do not design new technology by rather assimilate the designs of others. image
    • Vote Up +5 Vote Down
  • eye-zen
    0 eye-zen over 8 years ago in reply to jw0752
    Hi John
    Thanks for your reply.. i have tried of the shelf solutions and YES they work but it isnt what we are after.
    What im after is a schematic so we can incorporate it in to a board we are having built for robotics control..
    What we are after is something with a common input rail and then an output rail with selectable voltages - preferably selected by a switch or jumper..
    If anyone can provide a converter schematic and maybe an explanation of what components need to be changed for each voltage output level that would be ideal....
    0 jw0752 over 8 years ago in reply to eye-zen
    Hi Al,
    OK I understand better now. How much current will each of the taps draw? It is important to properly size unless weight isn't a problem for your application. Still, even if weight isn't a problem it is a shame to have 10 amps available and all the heavy duty hardware to support it when all you need is 100 mA.
  • eye-zen
    Hi John
    \The most current required is 3 amps - but mostly 2 amps is sufficient -- weight is kind of an issue but not necessarily a problem...
    0 dougw over 8 years ago
    Like TI tools:
    Power supply design for single loads | WEBENCHRegistered tools | TI.com
    SWITCHERPRO SwitcherPro(TM) Switching Power Supply Design Tool | TI.com
    Or Linear Technologies
    Solutions - Designing Power Supply Parameters in Five Simple Steps with the LTpowerCAD Design Tool
  • eye-zen
    0 eye-zen over 8 years ago in reply to dougw
    Hi Doug
    Those tools look amazing and can probably do what i need - HOWEVER - what i need is for someone to handhold me through the process at least -- assume im a total idiot when it comes to power supply design - because i probably am looking at what is involved...
  • eye-zen
    0 eye-zen over 8 years ago in reply to eye-zen
    Hi Al,
    If some of your circuits require less than 1 A there is a nice series of DC to DC converters from Recom. They will convert up to 28 volts in to fixed 3.3 V, 5 V, 9 V, 12 V, and 15V, at 1 amp and do it with nearly 90% efficiency so there is no a need for a lot of heat sinking. Further they are quite small. Here is a link to the 5 volt unit.
    http://www.newark.com/recom-power/r-78e5-0-1-0/dc-dc-converter-5w-5v-1a-sip/dp/83X9336?ost=R-78E5.0-1.0&scope=partnumberlookahead&exaMfpn=true&searchref=searchlookahead&searchView=table&iscrfnonsku=false&ddkey=http%3Aen-US%2FElement14_US%2Fw%2Fsearch
    If you want more than one Amp then it will require extra work. I suspect that one could put in the support hardware for the higher amperage output and perhaps use the little DC to DC converters as Plug in voltage selectors to drive the components that would deliver the higher amperage.
    You might note that while you will get questions answered and a lot of help on the forum it is unlikely that anyone will design the circuit for you. For one thing there may be liability issues if something that is designed fails and property is damaged or people are hurt. Some of the guys on the forum do circuit designs for a living and you may be able to contract with one of them to do your design for you but they will have to speak for themselves. I personally do not have the skills yet to take on a design project for someone other than myself. If you can find the resources to start designing and prototyping the board that you want I am sure that there will be help with the bumps in the road from the guys here.
  • eye-zen
    hi mate
    Liability is something i am aware of - and would not hold anyone here giving me assistance liable for anything except credit where credit is due....
    i am far from a litigious person -
    I am only hoping i can find the solution we require for our design ...
    Having said that maybe there is already enough info for us to progress -
  • eye-zen
    hi john to quote...."it is unlikely that anyone will design the circuit for you." that is actually pretty much what we needed - and we are prepared to forgo liability etc for a workig design - also if it is a commercial venture then so be it we are prepared to negotiate fair fee for service to get our design needs met....
