Power & Energy
Power & Energy
Forum How can I step up from 12V to 14V for about 80 W?
  • Subscribers 284 subscribers
  • Views 6393 views
H
I want to run a projector from my 12V circuit.
The projector is 14V and 3.5 Amp -
I don't really want to use an inverter.
Is there a simple way to step up 12V to 14V ?
thanks v.  much
  • Catwell
    Catwell over 14 years ago +1
    Matt, Here you go, Use an LM3481MM/NOPB LM3481MM/NOPB : http://www.newark.com/national-semiconductor/lm3481mm-nopb/ic-n-ch-controller-msop-10/dp/84M8119?in_merch=Popular%20Power%20Management%20Products…
    0 michaelkellett over 14 years ago
    What sort of projector and what sort of 12V circuit ?
    If the projector wants 14V DC it might work OK from 12V - check with the supplier (or just try it if you're feeling lucky).
    There is no way to efficiently convert 12V DC to 14V DC at 3.5A without using some kind of switching circuits - by the time you add all the necessary protection and emc precautions it won't be very simple.
    Michael Kellett
  • Catwell
    0 Catwell over 14 years ago
    Matt,
    Here you go, Use an LM3481MM/NOPBLM3481MM/NOPB : http://www.newark.com/national-semiconductor/lm3481mm-nopb/ic-n-ch-controller-msop-10/dp/84M8119?in_merch=Popular%20Power%20Management%20Products
    Cabe
    If you just want an off-the-shelf solution you may want to try to get a DC-to-DC converter from a company like Vicor. Look at: http://cdn.vicorpower.com/documents/datasheets/ds_vi-j00.pdf
    which offers up to 100W supplies in a half brick. However, many times these companies offer many different outputs and inputs, but do not stock non-standard one, but it may be worth a try.
    If you want to build your own as one replier suggested, ti.com or linear.com both have chips, circuits and on-line software to design supplies. Try National's (recently bought by Texas Instruments) WEBENCH at http://www.national.com/ and input the data into Webench Designer. With your input and output requirements they have about 7 or 8 different solutions including the LM3481MM/NOPBLM3481MM/NOPB from another replier.
    Lee
  • WVPhysicist
    0 WVPhysicist over 13 years ago in reply to e14 Contributor
    Why don't they make these nice new parts as through hole or better yet monsterous so an old hog like me can bolt them to a 2x4 and solder house wiring to the pins?
    try to find ac/dc charger for battery or diy self made ac/dc voltage control 220 ac to 14 dc
