Power & Energy
Power & Energy
Forum 120v led lamp
  • Replies 19 replies
  • Answers 2 answers
  • Subscribers 284 subscribers
  • Views 3309 views
120v led lamp
moelleux
moelleux over 11 years ago
Ive just started hacking electronics lately, thanks to Jeremy Blum book and tutorials!
My desk lamp fluorescent bulb gave up on me and i wanted to replace the bulb with some white LEDs.  So i took appart the lamp and found a circuit board and im not sure what it is for. The fluorescent bulb is rated 120V and i tought it was directly hooked to AC? is this board an AC to DC converter?
Heres some pictures (The side with the fuse is the 120v AC in) :
20141030083725 - HostingPics.net - Hébergement d'images gratuit
20141030083741 - HostingPics.net - Hébergement d'images gratuit
20141030083754 - HostingPics.net - Hébergement d'images gratuit
20141030083813 - HostingPics.net - Hébergement d'images gratuit
So my plan is to enclose a AC to DC converter to a potentiometer that would feed current to around 20 white LEDs(maybe those MCL034SWC-YH1MCL034SWC-YH1. This is my main light source in that room so i would like it to be very bright, but dimmable.
Thanks!
Feel free to recommend me stuff!
    shabaz over 11 years ago in reply to supper_slash +2
    Hi Lupe, Not sure that circuit will work, unless there is something I don't understand about the 555 (quite likely). Anyway, there is a great resource here, with plenty of 555 circuits - including PWM…
    jw0752 over 11 years ago in reply to moelleux +1
    Hi William, I also wanted to make sure you used 100 nF caps where indicated. These are also labeled 0.1 uF. If we get the capacitance too high we lower the frequency of the 555 which would allow you to…
  • moelleux
    moelleux over 10 years ago +1
    It's been a while, but i thought i would share it anyway. I've been using it for almost a year now and it's great lighting. Especially for phone repair and precision stuff. I made 2 versions of the board…
    0 jw0752 over 11 years ago in reply to shabaz
    Hi Shabaz, Yes I noticed all the goodies on the site. It was a litttle like opening a treasure chest for me.
  • moelleux
    0 moelleux over 11 years ago in reply to shabaz
    Thanks for all the links, it seems pretty well written.
    ill try this out once i receive my chips and mosfets!
  • moelleux
    I finally got some stuff done! I made the exact same thing as below with a 15v psu. Everything seem fine except the leds are blinking quickly instead of dimming. I tryed adding 470uf caps but it dont seem like doing anything.. would i need a larger cap? or maybe its the 555 that would need adjustment to run 15v?
    any idea would be appreciated
    0 jw0752 over 11 years ago in reply to moelleux
    Try changing the 100nF cap between pins 6 and 2 to ground. Try a 50 nF or a 10 nF as this should increase the frequency of the 555. Also make sure you have current limiting resistors on the LEDs.
    Hi William, I also wanted to make sure you used 100 nF caps where indicated. These are also labeled 0.1 uF. If we get the capacitance too high we lower the frequency of the 555 which would allow you to see the  effect of the PWM. I do not think that the 15 volts is the problem as the 555 is designed to run at that voltage. Let me know how it works out.
  • moelleux
    0 moelleux over 11 years ago in reply to jw0752
    Thanks for the advice, now it works perfect.
    i tryed 56nF but it was still flickering a little.  Then i tryed 33pF and it cant be noticed anymore.
  • supper_slash
    0 supper_slash over 11 years ago in reply to moelleux
    Keep up the great work John.
  • moelleux
    0 moelleux over 10 years ago
    I made 2 versions of the board to get it right and burned a resistor when i first plugged it in but it has not taken fire since!
    Thanks again for the help! feel free to comment
    0 jw0752 over 10 years ago in reply to moelleux
    Hi William,
    Thanks for the update.
