Power & Energy
Power & Energy
Forum Need to get MG Electronics Power Supply repaired...or NOT!?
  • Replies 120 replies
  • Answers 51 answers
  • Subscribers 285 subscribers
  • Views 14696 views
Hi.
I just bought a lot of Slot Car stuff, yes those cars that go around a track. The guy was serious about his hobby he didn't have the usual wall plug in power pack, he used a MG Electronics PS-10AD, 0-20 VDC at 10 Amps. Well this power supply doesn't work anymore. It does turn on and the red overload light stays on. It doesn't put out anything. I used my multimeter etc., nothing. I know that these are made overseas . They did retail for about $200. So the questions is were can I get it repaired OR should I ? I'm in Western MAss.
I did check the fuse , it's fine. I've got a heavy door stop on my hands, it does have a nice handle and cord on it !
Many thanks for info, Ted
http://www.mgelectronics.com/shopexd.asp?id=179
  • mpulliam
    mpulliam over 5 years ago in reply to jw0752 +4 suggested
    Well, I spent all day replacing four 2N3055 transistors....it wasn't easy and... Success!!!
  • mpulliam
    mpulliam over 5 years ago in reply to jw0752 +3
    Hi John, I have a thought. If the output transistors (or is it pass or power transistors?) NTE130 or 2N3055H are giving a bad voltage reading in the voltage test, could it be that any component between…
  • mpulliam
    mpulliam over 5 years ago in reply to mpulliam +3 suggested
    BTW I tested the old 2N3055 transistors, the continuity is the same as a new 2N3055 . There is no continuity between any of the terminals But when I run a diode test, a new 2N3055 tests at .486 volts with…
    0 jw0752 over 5 years ago in reply to mpulliam
    Hi Matt,
    Here is another experiment I would like you to try. There are two large capacitors on the board with the diodes. I would like you to set your digital meter to DC volts. Turn on the power supply and measure the voltage across the capacitor leads in each of the settings of the range control on the front panel. We may get different voltages and we may get only one voltage. This may tell us something about the actual circuit design. Do this test for each of the two filter capacitors. Note the lead that is closest to the line on the side of the capacitor is the negative. Let me know what you find out.
  • phoenixcomm
    0 phoenixcomm over 5 years ago in reply to e14 Contributor
    tedbier check to see if you have power in the following places:
    1. Check the fuse with an dvm ohms..
    2. where the power cord terminated: yes move on; No replace cord
    3. check the seconary across the bridge. Yes, Regulator is bad
  • mpulliam
    0 mpulliam over 5 years ago in reply to mpulliam
    The diode test on the power transistors yields .010 volts between the base and the emitter in both polarities while the transistor is in circuit.  All four power transistor yield the same results
    The diode test isn't going to tell us much on the power transistors. You could try to test them with the analog meter. They could be hooked in parallel and if one was bad but not shorted you would not see it.
  • mpulliam
    0 mpulliam over 5 years ago in reply to jw0752
    Voltage Test for large capacitor (both measured exactly the same)
    at 0-7V = 16.50V
    at Mid-mark = 24V and falling
    at 7-14V = 26.09V
    Mid-mark = 35V and falling
    at 14-20V = 36.7V
  • mpulliam
    LM741 IC Tests
    Top Left IC
    Pot at Full CCW
    1 = 5.2mV
    2 = 6.22V
    3 = 6.33V
    5 = 4.8mV
    6 = 17.71V
    7 = 18.33V
    8 = 35mV and falling past 20mV
    Pot at Full CW
    1 = 4.9mV
    2 = 6.22V
    3 = 6.33V
    5 = 5mV
    6 = 17.71V
    7 = 18.33V
    Bottom Right IC
    Pot at Full CCW
    1 = 9.6mV
    2 = 6.33V
    3 = 6.98V
    5 = .6mV
    6 = 18V
    7 = 18.33V
    8 = 30mV and falling past 20mV
    Pot at Full CW
    1 = 10.1mV
    2 = 6.33V
    3 = 10.20V
    5 = 2.5mV
    6 = 18V
    7 = 18.33V
    8 = 96mV and falling
    Hi Matt,
    Good Job. The only one that looked suspicious to me was the bottom right with full CW the pin 3 did not look right but we will wait and perhaps check it again later. I think this information will be helpful. It looks like the range selector switch is picking a voltage tap from the transformer to feed to the output transistors so that they do not have to over regulate and get too hot. I believe the intermediate settings on the switch are just off positions that is why the voltage is dropping.
    Back to the output transistors. From the drawings I could see that the yellow wire went to two of the output transistors. Does it go to the same spacial pin on each of the 4 output transistors? Do the other wires from each transistor happen to tie back to the same connection point? If possible draw a diagram of the output transistors and show where the wires go.
    Let me know what the results of using the Analog meter to test the output transistors is.
    I might ask to anyone who has been monitoring this process, particularly, genebren  if they have any insights or if they can propose any other tests we can run to try and figure out why this unit seems to have voltage to all the power and control circuits but doesn't put out any power. I haven't yet seen any indication of an overload circuit that might be clamping off bias to the output transistors. I expected some variance in the  2 and 3 pins of the LM741s with the potentiometer turned from one extreme to the other but except for the anomalous reading on pin 3 in the full CW position nothing seems to be changing.
  • mpulliam
    Reconfirm Lower RIght LM741 IC  with Pot at full CW between Pin 4 and Pin 3
    10.16V
    I believe all the transistors are wired the same, except the ones on the left side have two yellow wires, the transistors on the right have one yellow wire.
    The wires get lost in a bundle, I can't follow them.  It seems they end up at the board and potentiometer.
    But each transistor yellow terminal has continuity to all other yellow terminals, each red terminal has continuity to all other reds, each blue terminal has continuity to all other blues.
    How should I test the transistors with the analog multimeter?
    0 genebren over 5 years ago in reply to jw0752
    John,
    I have been following your steps in helping to solve this issue with great interest.  I wish that I could be of more help, but my days of being a technician and doing any real heavy device debugging are sadly for behind me.  I tend to fix broken equipment by buying a replacement.  To that end, my search skills have have found a couple of replacement power supplies (same brand - one for 99.00 and free shipping).  Let me know if you need any details.
    I am (and always have been) in absolute awe of people who can fix broken gear and save it from the trash.  I seem to have a phobic thing that prevents me from opening up anything.  With a schematic and plenty of time, I have a fairly good chance of figuring it out.  But my running 'blind' skills are severely lacking.
    Best of luck guys!  I will continue to follow along, and who knows, maybe I will come up with some way to help.
    0 shabaz over 5 years ago in reply to mpulliam
    Hi Matt,
    I tried following the thread and it's hard to follow, but it got me wondering, does slot car racing need such a supply?
    It seems overkill, and I can see that it could fail through accidental misuse, or even damage the slot-cars if set accidentally to too high a voltage.
    Probably a few amps is enough, if it is a 'scalextric' style slot car racing system.
