Power & Energy
Power & Energy
Forum Visual Signs of Capacitor Failure - Bulging
  • Replies 28 replies
  • Subscribers 281 subscribers
  • Views 11797 views
Jan Cumps
Jan Cumps over 2 years ago
I received a new TV box from the cable provider They suggested to drop the old one at an electronics recycle collector. That didn't happen Slight smile - I opened it up. I've put the internal hard drive for sale on a 2nd hand site. For the other components, I'm checking what (if anything) is worth keeping.
What caught the attention, is that one of the electrolytical caps is beyond end-of-life. It's definitely bulging: It's the first time that I see one where the symptom is so obvious. I had others that failed or leaked. But never such a visible sign of the internal pressure effects.
Can you spot the culprit?
Title inspiration: capacitor labs.
    dougw over 2 years ago +4
    The top isn't flat anymore....
  • beacon_dave
    beacon_dave over 2 years ago +3
    Jan Cumps said: It's definitely bulging: It's the first time that I see one where the symptom is so obvious. I had others that failed or leaked. But never such a visible sign of the internal pressure effects…
    michaelkellett over 2 years ago in reply to shabaz +3
    If you want low noise then put some little ceramic caps around the rectifier. Doing so is mentioned in AOE Edition 3 (maybe in the X pages book) and after I read that I measured a design I was working…
    michaelkellett over 1 year ago in reply to beacon_dave
    Those RIFA X caps blow up everywhere !
    I replaced 2 in a Kenwood food processor (age unknown but quite old) the other month.
    Jan Cumps over 1 year ago in reply to michaelkellett
    Yes. The housing becomes brittle, and attracts condense. Guaranteed recipe for failure.
    shabaz over 1 year ago in reply to michaelkellett
    There's a new TV show called Retro Electro Workshop and this weeks episode had a Kenwood food mixer smoking : )
    And it was the same problem!
    I don't know if the show is good or not; I have not seen any other episode, it was just on in the background, and I watched it for a few mins here and there.
    michaelkellett over 1 year ago in reply to shabaz
    That's the very mixer. The RIFA cap at the other end of the board was bulging but hadn't started exuding the brown goo !
    dougw over 1 year ago in reply to shabaz
    I don't count myself as a power supply expert, but would also put a low ESR cap on Vout.
    shabaz over 1 year ago in reply to dougw
    This particular voltage regulator expects ESR within a range, they suggest tant or alu electrolytic on the output. I'm very comfortable with using tantalum for that, even though more modern ICs can use ceramic.
    Overall I'm really happy with this IC, it has an OKish price, large easy-to-solder package, and way better than typical LM7805 etc! I will probably build another circuit with it at some point, and this time take measurements.
  • bidrohini
    bidrohini over 1 year ago
    The electrolytic capacitor at the front right side of the board, near the edge, appears to have a bulging top. That means it is at the end of its life span. Since you can read the value, it is better to replace it. You can also test this capacitor with your multimeter. www.richardelectronics.com/.../how-to-test-a-capacitor-with-a-multimeter
    Jan Cumps over 1 year ago in reply to bidrohini
    The device it was in, is also end of life.
    Looking back, I should have measured the capacitance and ESR before disposing it. Just to see how far off it was.
    The device itself, a cable TV decoder with hard disk for recording, was still operating well. Even with that cap being like that.
