Robotics
Robotics
Forum Making robot and machine parts; ask questions
  • Subscribers 77 subscribers
  • Views 1180 views
  • research
  • robotics
  • robots
  • control
  • robot
  • on_campus
  • learning
  • new_technology
  • school
  • human_interaction
  • university
  • automation
  • teaching
Catwell over 14 years ago
One of the first CNC machines I built. Performing 2 complete circles. (Via Cabe Atwell)
So, you want to build a robot, what is holding you back? Let me briefly share how I ended up designing and building industrial robotics.
When I first started, I found the biggest hurdle coming from my inability to create quality parts. I refused to use wood, PVC, or any ad-hoc design method. For me, +/- 0.0001" precision was necessary. I started with a few small machines. On those I was able to make what I needed. I even made machines and fixtures to help improve the quality. (Keep in mind, the highest quality machines long ago were built by human hands. Then that machine made even higher-quality  components. And today, we have 16 axies, $500K machining centers. It all starts somewhere.)
Over time, I developed my own machine shop. I taught myself to be a rather proficient machinist. I designed and build my own CNC machinery, which lets me make parts I could never do by hand. More recently, I taught myself SolidWorks, which elevated my design capabilities to new heights. Now, I can make anything.
Since, I could have used some help when I first started, I am offering to help any of your aspiring robotics designers/machinists out there with making some parts. I occasionally have some down time at my shop, and would be happy to help anyone down the design path.
Just send me a private message if you need any parts made or need help.
Otherwise, what are you working on? Share some design challenges you overcame. Alternatively, ask a question about robotics or machining.
Cabe
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to DAB +1
    Cabe, PM'd you an idea. E
    DAB over 14 years ago
    Hi Cabe,
    I just received an email that my CNC kit from DYICNC has been shipped.  This is my first step into the machining world, but I am excited by the potential.  I hope to put a blog together as I assemble the device so that the community can see how to get into CNC for a relatively low cost.  I don't know how well it will stack up to your machining requirements, but we shall see.
    Thanks to you and others in the E14 community, I now have the inspiration to build my own devices.  Perhaps another Evil Genius will be born. image
  • alanwood
    alanwood over 14 years ago
    Thanks for you generous offer Cabe.
    I reckon that with a bit of programming, you could play a tune on that!
  • Catwell
    Catwell over 14 years ago in reply to DAB
    Alan,
    I am glad to help.
    Dab,
    CNC is not intimidating at all. If you need help with anything, just message me.
    What type of CNC device are you making?
    Cabe
    DAB over 14 years ago in reply to Catwell
    Hi Cabe,
    I ordered the CNC from the www.MYDIYCNC.com  group (I got the link from a post here at E14 and liked what they offer.).  It enables the user to mill, drill, or cut wood, plastics or light metals.  I also inquired if they were going to add a 3D print head and they confirmed that it was on their list to do.  They also have a laser head for the device, so I thought it would be an easy way for me to try some things out.
    The full kit was under $500 US and they have a website where you can see what they are doing and check the progress of your order.  So since mine is in the UPS system, I should see it soon.  After that I need to assemble and test it before I start getting creative with it.
    I plan to do at least a blog with pictures of the kit and my assembly progress.  I appreciate the offer if I get stuck, but it looks pretty straight forward and the group has been very good at responding to my questions, so I don't anticipate any problems.
    I have a neat, but undisclosable, project in mind.  Once I get some results, I will try to post some pictures.
  • Eavesdropper
    Cabe,
    PM'd you an idea.
    E
    G'day Mate,
    Total neebie here, sorry if these questions have already been answered but I have searched and searched and I can not find a definative answer
    I am in the process of building my first cnc mill/router,
    I have the frame with the 3 axis, no motors in yet,
    I have a HY-JK02-M-5axis interface board it runs 5vdc, from the printer port or can use usb which is a switch on the board,
    I also have 3 YM2754 5 wire unipolar stepper motor rated at 12vdc,
    The questions I have is can the board run the motors, or do I require some form of switch (npn or pnp or mosfet) to power the motors?
    the motors have 5 wires but the board only has 4 terminals for each axis, how do I connect the motors to the board? I know 1 wire is common and I belive that depending on how you wire it it can have full, half, quarter, or micro step.
    If I require some form of switch, will 1 switch do all 3 motors or do I need a different switch for each motor?
    If I require a switch, could you do a simple circuit diagram, (I can't spell schematic, lol) and parts list for me, Obviously I could use the same circuit for each motor if I have to.
    Thank you or anyone who can help me in advance.
    It will be very much appreciate it.
    Damien
