      • Japan
      • Vietnam
PCB Design, Prototyping and Production
PCB Blogs Raspberry Pi RP2350 based PCB design
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Author Author: embeddedguy
  • Date Created: 19 Jun 2025 8:16 AM Date Created
  • Views 2350 views
  • Likes 10 likes
  • Comments 16 comments
  • pcb
  • raspberry pi
  • rp2040
embeddedguy
embeddedguy
19 Jun 2025
Sometimes back, I was designing a PCB based on RP2350 and now I received the finished PCB. So this post is about the experience that I would like to share about my PCB design.
Firstly, the original plan of creating this PCB was to create RP2350 based Single Pair Ethernet development board. For that I had used ADIN-1111 chip. Unfortunately, it was not available during the PCBA making. Hence the original idea was not possible. But I have tested the RP2350 chip and it is working fine.  The design is based on KiCAD and is 4-layer design.
The easiest idea to test this board is to use Micropython so that the board can be tested fast. I tested a simple blink program on this board and it works fine.
  • BigG
    BigG 6 months ago +1
    Very nice. Does your SPE board include PoDL (power over data lines)? That's a design challenge just on it's own. I've always fancied the microchip SPE ICEs over ADIN-1111, purely on price. I see Arduino…
  • embeddedguy
    embeddedguy 5 months ago in reply to aswinvenu
    Thank you.!
    PoDL is interesting a topic, but I still have to gather skills for that.
  • aswinvenu
    aswinvenu 5 months ago
    Awesome build! Infact I was also working on something similar with PoDL.
  • embeddedguy
    embeddedguy 6 months ago in reply to michaelkellett
    Maybe in this photo paste is visible clearly.
  • michaelkellett
    michaelkellett 6 months ago in reply to wolfgangfriedrich
    Would need either a fancy IR re-work tool or bottom heat and very careful use of hot air gun on the top. If unleaded solder on main board its very hard not to get the chip too hot without expensive tools.
    But I agree there is enough solder there to not need paste at all.
    MK
  • embeddedguy
    embeddedguy 6 months ago in reply to wolfgangfriedrich
    Right it has the paste already in place.
