Sensors
Sensors
Sensor Forum Do you have a question on MEMS Sensors? Ask our Expert, Donna Sandfox
  • Replies 73 replies
  • Subscribers 354 subscribers
  • Views 9822 views
  • products
  • Mechanical
  • components
  • photomicrosensors
  • sensors
  • expert
  • support
  • omron
  • mems
  • engineering
  • rf
  • switch
  • answers
  • mass_flow
  • vibration
  • question
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Sensors in the element14 Community Sensors group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Donna Sandfox
Donna Sandfox is the Product Manager for Sensors and MEMS Products for Omron Electronic Components LLC.  Her primary area of expertise is in MEMS Mass Flow Sensors.  She also supports Omron’s pressure, thermal IR, tilt/vibration and optical (photomicrosensors) sensors, as well as their RF MEMS Switch products.  Donna received her bachelor’s degree in mechanical engineering from Southern Illinois University and an MBA from Roosevelt University.
    e14 Contributor over 15 years ago in reply to DAB +1
    Hi Don! Thank you, and thanks for the question. While volumes can be written comparing and contrasting all of the different technologies available for measuring gas flow, I'll try to give a reasonably…
    e14 Contributor over 12 years ago in reply to vsluiter +1
    Hello, Thanks for your reply. The problem has now been solved. There was an error in the catalogue which has now been corrected. The correct sensors are with me and ready for test in my project. Thanks…
                  I have this accelerometer Sensor. How can i solder this on Copper clad board?? So it won't affect the sensor core! It's very small in size and delicate sensor. http://www.sparkfun.com/products/9605
    Thank you in advance!!
    michaelkellett over 14 years ago in reply to e14 Contributor
    If you have  a board with a footprint suitable for hand soldering (ie with the pads extending well outside the profile of the chip) you can easily solder it on by hand using soldering iron with a very fine point (< 0.5mm wide at tip) and plenty of flux. Use leaded solder for low melting point.
    If you don't have a board you could solder very fine (0.1mm dia ) bare wires to the pads and then solder the other ends to stripboard. You could glue the chip upside down to the stripboard. You'll still need that fine point iron.
    Michael Kellett
    Dear Madam,
    We are into marketing of flowmeters and deal with almost all types of flowmeters. We have an enquiry for 1000No.s Flow Sensors to measure fuel consumption (Diesel). Kindly let us know if you can offer the same. Following are the specifications:
    Flowrange: 0 to 100 / 200 / 400LPH
    Temperature: 9 to 50 Deg. C
    Pressure: 2kg/sq.cm
    Output: Pulse, 4 to 20mA, or any suitable.
    Kindly reply fast.
    Regards
    Y. Narasimha Reddy
    R.R. Flowmeters Pvt. Ltd.
    G1, Sai Thirumala Heights, Bhandari Layout, Nizampet, Hyderabad-500090, India
    Tel: 91-40-6461-2626, Fax & Residence: 91-40-4026-2627, Mobile: +91-9490-262626
    Website: www.rrflowmeters.com, Email: info@rrflowmeters.com, rrflowmeters@gmail.com
    SKYPE: ynreddi, MSN: info@rrflowmeters.com
    Hello, i´m a studing in France and right now i´m working in a proyect to developpe an Intelligent Sensor and i need a plateform to developpe my system and i need some some help to choise the correct device, in the first stage i will mesure 3 signal comming from 3 sensors like the ADXL335, ADXL212 and ADXL345BCCZ.ADXL345BCCZ.. so the  caracteristics that i need are:
    3 voies( channels) analogiques 12 bits or de entrees PWM or I2C or SPI.
    Being capable to integrate 500 equations diferrentiels of second ordre each step of time ( grande puissance de calcul)
    Being capable to communicate by a Serial port in 9600 baud for it´s configuration.
    Have autonomy of operation and.save the data even in case of cut of the supply voltage, min 2 months
    I thank you for your time, and i hope your answer soon.
    I´m sorry by my mistakes in ortography.
    What is the cost effective force/pressure sensor? need to be small size.
    Hi Donna.
    I ordered urgently sensor D6T-44l-06, sensor arrived on my company account and yet to discover that there is no proper technical documentation which i need to finish project with this sensor.
    In order to use sensor I need some information about serial protocol, registeres and function of the sensor. There are general technical pdf files for that sensor which is only on introduction level.
    Where can i find full documentation for that sensor?
    Best Regards
    Alex Tomic
    Senior electronic R&D eng.
    Alex,
    Please send me an email, and I will get additional D6T documentation sent to you.
    donna.sandfox@omron.com
    James,
    I am not familiar with force sensors, however, the Omron 2SMPP family gage pressures sensors are very small in size and cost effective.
    http://www.components.omron.com/components/web/webfiles.nsf$FILES/family.html?ID=GTAA-8ETU9V
    Thank you very much Donna.
    I all ready sent you one e mail, here just my e mail address...
    alekt@pcme.co.uk
    Best Regards
    Alex
    Dear Madam,
    We have experienced certain problems with your mass flow sensor D6F-10A5-000.
    Our test bed consists of a particulate filter, a sample filter for gas (NO2) normally 7-8 µgm-3, your mass flow meter,  a plenum to filter out pump noise and a rotary vane pump.
    The flow is nominally 0,5 lpm. Pressure drop negligible.
    Earlier in the lab we had two “dead” flow meters. Cause of death unknown.
    In May and June we tested 3 units in parallel. One sensor malfunctioned very shortly after about two weeks of running. The sensor was exchanged immediately.
    Towards the end of our 8 week test the two other units also failed.
    The sensor is fed a stable 12 VDC.
    The sensor reports zero flow and the system consequently speeds up the pump to maintain flow.
    The analysis shows a very high concentration with almost no flow! Parallel samplers show normal values.
    What leads to the failure? As far as we now, no water has entered the sensor.
    We would appreciate if you could enlighten us as we think that this sensor is used world-wide and should expect longer life time.
    Looking forward to your answer
    Kind regards
    Harald Willoch
    Elektronikkingeniør/ BScEE
    Avdeling for måle- og instrumentteknologi / Monitoring and Instrument Technology Dept.
    NILU - Norsk institutt for luftforskning
    1. Tel.:
    (+47) 63 89 81 04
    Norwegian Institute for Air Research
    Fax:
    (+47) 63 89 80 50
    PO Box 100, 2027 KJELLER
    1. Mob.:
    (+47) 91 61 35 10
    Besøk/visit: Instituttveien 18, 2007 Kjeller
    E-mail:
    1. harald.willoch@nilu.no
    2. www.nilu.no
    3. Org.nr.:
    941 705 561
