Sensors
Sensors
Sensor Forum Sensor to detect foot steps on floor
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 353 subscribers
  • Views 7009 views
  • sensors
  • seismic
  • acceleromenter
  • geophone
  • mems accelerometer
  • sensor
crjeder
crjeder over 10 years ago
Hi!
I am thinking of trying person identification through their foot step sound / vibration. This is should be entirely possible because humans can do it and some research papers exist on this topic. But here comes the question:
Which (low cost) sensor(s) should I use?
Options I consider are:
  • Geophone
  • Accelerometer
  • Microphone
  • Vibration sensor (piezo)
Geophones are expensive, starting at around 60 EUR, microphones are not good at low frequencies, accelerometer and vibration sensor might be not sensitive enough. Any Ideas?
Edited to add:
Are accelerometers sensitive enough to detect foot steps several meters away (asuming a hardwood floor)?
Any specific products you can recomend?
Thank you!
    dougw over 10 years ago +1 suggested
    Piezo disks are very low cost and probably sensitive enough, depending on the floor and the shoe. I just tried my desktop sensor and it easily detects me walking on a hard wood floor in my socks from 12…
    dougw over 10 years ago in reply to bwellhouse +1
    Good suggestion Brian, That PolyVinylIdeneFlouride film (PVDF) is extremely sensitive piezo material. I have a piece somewhere connected to a neon light bulb. Just waving the film around will light the…
  • clem57
    0 clem57 over 10 years ago
    How about a combination or hybridization approach.
    Clemm
    0 shabaz over 10 years ago
    This could work with some filtering, e.g. low-pass:
    Impact, Vibration and Ultrasound Sensing with PVDF Piezo Sensors
  • crjeder
    0 crjeder over 10 years ago in reply to shabaz
    Thanks, will definitely read throug it.
  • crjeder
    0 crjeder over 10 years ago in reply to clem57
    First I have to select at least one sensor capable of recognizing steps at all. To improve results a hybrid aproach could work.
    0 michaelkellett over 10 years ago
    An accelerometer of the right type can easily do what you want.
    The problem is that you will probably need to make your own since the typical low cost MEMS parts may be too noisy.
    Find the Analog Devices chip accelerometer with the lowest noise and give it a try.
  • crjeder
    0 crjeder over 10 years ago in reply to michaelkellett
    Thanks! That is one of my problems: I have no Idea of how strong the "signal" and the noise is. From the papers the frequency is around 5 to 100 Hz. Which rules out some of the sensors with integrated logic because the include filters. Found no information on the amplitude of the signal...
  • crjeder
    0 crjeder over 10 years ago in reply to crjeder
    Found one paper citing a value of 3 x 10^-6 m/s for the signal and 8 x 10^-6 m/s for the noise in urban areas.  But this is for the vibration not for acceleration. (https://www.researchgate.net/publication/252566889)
    0 DAB over 10 years ago
    I would start with a throw rug with embedded capacitive sensing.
    That way out can get measurements on shoe size, gait, stride and other data for isolating the correct person.
    0 dougw over 10 years ago
    I just tried my desktop sensor and it easily detects me walking on a hard wood floor in my socks from 12 feet away. Just normal soft walking - not stamping along. It was designed to detect small vibrations on my desk, like dropping a business card, and it locks out subsequent triggers for a couple of seconds so it doesn't continuously stay triggered. Because of this lockout feature it is not going to trigger on every footstep, but it is sufficient to prove feasibility.
    You can see it in action on my desk in this blog:
    Tis The Season For Arduino
    Data from sensors like this would be mostly useful to detect event timing, as in when a foot contacts the ground - the waveforms would be hard to analyze if you want to extract more information than this from the signal. Even extracting useful amplitude data would be problematic ..... Possible, but requiring some careful thought about the signal and signal processing.
  • bwellhouse
    0 bwellhouse over 10 years ago
    Have you checked out Piezo Film?  DT Series with Lead Attachments—Piezo Sensors—Film Elements—Measurement Specialties
