Sensors
Sensors
Sensor Forum liquid level sensor
  • Replies 15 replies
  • Answers 2 answers
  • Subscribers 353 subscribers
  • Views 3202 views
  • level
  • sensor
liquid level sensor
hi,
i am designing a remote monitoring system for a small solar water heater. in this set up the water vapor is condensed and is collected in a container.I need to find a suitable sensor for measuring the collected liquid level.The amount of liquid collected is very minimal and the container is open at the top.If anybody have a suggestion please reply immediately.
    jw0752 over 11 years ago in reply to e14 Contributor +1 suggested
    Hi Aiswaryaa, Have you checked out Spark Fun? They have a liquid height sensor. https://www.sparkfun.com/products/10221 John
    dougw over 11 years ago +1
    Any capacitance measurement circuit can be used to measure water depth as accurately as as your capacitance meter. The capacitor "plates" to be measured are simply vertical wires running up the length…
    dougw over 11 years ago in reply to markvenn +1
    It would work fine even with pretty large spacing and it doesn't matter if the container is conductive, although with a conductive container it would work better if the sense (insulated) wire is at least…
  • gadget.iom
    0 gadget.iom over 11 years ago
    Water level controller using arduino
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    thanks for your reply.I want a sensor for continuous level measurement.The one you have suggested is of point type.Can u suggest me any continuous level sensor? i need to get an output for minimal changes in the water level.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    What range are we talking?
    at a maximum of 250-500 ml in an hour
  • gadget.iom
    Are you measuring flow or height?
    i will be measuring the height.
    0 jw0752 over 11 years ago in reply to e14 Contributor
    Hi Aiswaryaa,
    A potmeter  in a joystick and a floating ball should also do the trick. Calibrate one side to empty other to full then read the value from the jøystick connector..
    0 dougw over 11 years ago
    Any capacitance measurement circuit can be used to measure water depth as accurately as as your capacitance meter. The capacitor "plates" to be measured are simply vertical wires running up the length of your container. The capacitance between the wires is directly proportional to the depth of water. One of the wires cannot be permitted to contact the water, so it needs to be insulated wire - I just run an insulated wire to the bottom and back up, to avoid having to seal the bottom end. The higher the dielectric constant of the wire, the larger the capacitance reading. For your small depth application you should use teflon coated wire for a high capacitance, but you can also increase capacitance simply by running more loops of wire to the bottom and back.
  • D_Hersey
    0 D_Hersey over 11 years ago
    An op-amp-based capacitor multiplication circuit can make your sense capacitor appear 100x larger.  You can use the capacitor as the timing element in an oscillator and use the counting function of a uP to determine its value.
    Clever idea, Dennis!
