Sensors
Sensors
Sensor Forum liquid level sensor
  • Replies 15 replies
  • Answers 2 answers
  • Subscribers 353 subscribers
  • Views 3216 views
  • level
  • sensor
liquid level sensor
hi,
i am designing a remote monitoring system for a small solar water heater. in this set up the water vapor is condensed and is collected in a container.I need to find a suitable sensor for measuring the collected liquid level.The amount of liquid collected is very minimal and the container is open at the top.If anybody have a suggestion please reply immediately.
    jw0752 over 11 years ago in reply to e14 Contributor +1 suggested
    Hi Aiswaryaa, Have you checked out Spark Fun? They have a liquid height sensor. https://www.sparkfun.com/products/10221 John
    dougw over 11 years ago +1
    Any capacitance measurement circuit can be used to measure water depth as accurately as as your capacitance meter. The capacitor "plates" to be measured are simply vertical wires running up the length…
    dougw over 11 years ago in reply to markvenn +1
    It would work fine even with pretty large spacing and it doesn't matter if the container is conductive, although with a conductive container it would work better if the sense (insulated) wire is at least…
  • D_Hersey
    0 D_Hersey over 11 years ago
    Another idea is to mass the container.  You can get a weigh scale from ebay with RS-232 output for pretty cheap.  If you like to get down to the nitty-gritty, you can get a load-cell from there and condition its signal using open-source technology from Analog Devices.
  • D_Hersey
    http://www.ti.com.cn/cn/lit/ug/tidu367/tidu367.pdf
    Our friends at Texas Instruments have been having fun weighing things by suspending them with springs, then using the changing inductance of the spring to FM an oscillator, which they count.  This might be the perfect system for you.
    0 e14 Contributor over 11 years ago in reply to D_Hersey
    hi Don,
    thanks for the link.I really found it useful.
  • markvenn
    0 markvenn over 11 years ago in reply to dougw
    Douglas
    Is there a maximum distance apart that this would work? I don't mean miles, just should it work across a bath tub sized gap? Assuming not an iron bath tub.
    0 dougw over 11 years ago in reply to markvenn
    It would work fine even with pretty large spacing and it doesn't matter if the container is conductive, although with a conductive container it would work better if the sense (insulated) wire is at least a couple of inches away from the edge.
