Sensors
Sensors
Sensor Forum Problem with MICROSTACK   BASE BOARD and L80
  • Subscribers 349 subscribers
  • Views 704 views
I try to use these two modules with RPi2 :
MICROSTACK BASE BOARD - MICROSTACK - ADAPTER CARTE ADD-ON POUR RASPBERRY PI | Farnell element14
http://fr.farnell.com/microstack/microstack-gps/carte-add-on-l80-gps-raspberry/dp/2434228
Following instructions, I have installed all necessary software in Raspbian but without any success : I have a GPS time out error using cgps -s
Is it because the GPS hasn't fix any position ?
Can I use this GPS without any antenna ?
I suspect the module to be brocken...
Any help would be very appreciated.
frank
    Try cat /dev/ttyAMA0 if this doesn't work, then you need to reconfigure /root/cmdline.txt.
    I tested this, and it's working properly.
    https://learn.adafruit.com/adafruit-ultimate-gps-on-the-raspberry-pi/using-uart-instead-of-usb
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Petri,
    Ok I will try to work around ttyAMA0 and cmdline.txt.
    Your link is not working for me : Could you give an updated link please ?
    Thks for your help,
    frank
    finally, it was because I made indoors tests without any antenna ! Putting Microstack GPS  near window solved the problem !
