Test & Tools
Test & Tools
  • Views 2995 views
  • Comments 21 comments
  • signal
  • am
  • 33622a
  • fm
  • transmitter
  • radio
  • blog
  • road_test
Robert Peter Oakes
Robert Peter Oakes
21 May 2014
90.5Mhz
1.414 VRMS output
Frequency Modulation
240Khz frequency deviation
External Modulation
1 Volt Modulation input
740Khz frequency,
Amplitude Modulation ,
100% depth of modulation,
External Modulation
1V modulation input...
Easy
so here is the show
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to Problemchild +1
    DAB over 12 years ago
    Your video crashed my IE browser.
    Now I wonder what you embedded in it to kill it. image
    Robert Peter Oakes over 12 years ago in reply to DAB
    Nothing embedded except me and my madness, and IE is more than used t that I assure you image
    let me know, i'm not sure if I could do anything abut it but who knows
    DAB over 12 years ago in reply to Robert Peter Oakes
    Ok I tried it again and everything works fine.
    I must have just had a bad download.  image
    Great video.
    Thanks, made a bit of a fool of myself but underneath it all, quite educational and fun
  • Problemchild
    Problemchild over 12 years ago in reply to Robert Peter Oakes
    I'm glad I would like  to see more videos like this show me and entertain me...remember when it was all fun folks image
    I will endeavor to keep you entertained image
