Test & Tools
Test & Tools
Blog 33622A used to measure Capacitors and Inductors - Curve method
  • Date Created: 18 May 2014 6:48 AM Date Created
  • Views 1062 views
  • RoadTest
  • test
  • masure
  • capacitors
  • 33622a
  • and
  • blog
  • inductors
  • awg
Robert Peter Oakes
Robert Peter Oakes
18 May 2014
With the 33622A Arbitrary Waveform generator I was sent for review from Element 14, I have discovered it is possible to use it for some basic component measurements with surprising accuracy
this is a link back to the primary review http://www.element14.com/community/roadTestReviews/1744
In this blog I will show you how to use basic techniques to derive the value of unknown capacitors and Inductors
All you need is a fast pulse (Compliments of the 33622A), an oscilloscope and a known value Resistor set (1K, 10K, 100K and greater), really any values will do, you just need to know the real value.
The test schematics:
So without further ado, lets measure some caps
33622A Setup and sample scope display
Initial Setup for capacitor measurement and sample displays for "Scope Probe" and then C3 with a 10K resistor
The capacitor tests being performed using the 33622A as a high accuracy and quality square wave generator
Setup for Inductor measurement, Un-Expanded ringing view, Partly expanded then expanded view in order to measure ringing frequency
The Inductor Tests being performed using the 33622A as a quality square wave generator
Now that all the measuring is completed, here is the Math
EXCEL Spreadsheet Math
R in Ohmstime in SecondsC Calc in Farads
C DMM
Measured
Marked
on device
C01008001.56E-061.54762E-118.43E-10
C11008001.17E-031.16071E-081.10E-0810nF
C199601.17E-041.1747E-081.10E-0810nF
C299609.80E-049.83936E-089.73E-08100nF
C310015.50E-035.49451E-065.54E-064.7uF
C410011.11E+000.0011088911.01E-031000uF
fw: (2*PI*F)^2H: (W * C)uH
L11329006.97284E+111.46E-0514.58
L222620201997008565.03E-04503.14
L329070333618250253.05E-04304.64
L420000157913670426.44E-04643.60
Inductors And Capacitors.xlsxInductors And Capacitors.xlsx
    DAB over 12 years ago
    Hi Peter,
    Good post.
    This is one of those exercises I wanted to do, but never found time to do it.
    We just take the stated values of components at face value and we just assume that they are within the tolerance range.
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to DAB
    What I find more interesting is that people assume their test measurement equipment have no affect on the measurement forgetting the 1Mohm or 15pF input loads it applies thereby distorting the measurements in many cases
