Test & Tools
Test & Tools
Blog DIY Source Meter Unit - initial thoughts
  • Date Created: 6 Jun 2020 11:36 AM Date Created
  • Views 6169 views
  • Likes 10 likes
  • Comments 16 comments
  • opamp
  • smu
  • analog
6 Jun 2020
I'm thinking about building a low power SMU.
We're playing with OpAmps and discrete semiconductors regularly over here, and there's a Keithley 2450 SMU with I-V Tracer Software  road test going on.
Learnings from those activities can be applied here.
image: over simplified concept
Goals:
Only two;
  • Make a Source Measure Unit.
  • Make it programmable or scriptable
Possible capabilities:
This would be a low power instrument, µA up to maybe a few mA. Low voltage. A utility that can be used with analog low power devices.
Source and sink voltage and current. positive and negative.
Constant current, constant voltage.
(undefined) precision and speed
It should be possible to make this modular:
  • the driver part
  • the measure part
  • controller and converters
  • human and digital interfaces
I'm going to read up on the subject now. Ideas and support are welcome.
    shabaz over 6 years ago +7
    Hi Jan, There's a couple of open source SMU-like devices that might be worth exploring, in case it gives some ideas for your project. One is ADALM1000 ADALM1000 see here for more info Getting Started with…
  • michaelkellett
    michaelkellett over 6 years ago +6
    If you like to use it my power amplifier as blogged about in: Frequency Response Analyser Progress would be a possibility for your driver section. I'll have some boards soon (Fedex say Monday) and some…
  • jc2048
    jc2048 over 6 years ago +6
    This is interesting. Several times when I was doing the transistor blogs I wondered about about doing some kind of modular test setup [though it was fun designing the ad-hoc circuits and wiring the prototype…
  • dustooff
    dustooff over 6 years ago
    Hi Jan,
    I also have an interest in SMU's for various test purposes, have been collecting ideas for a few months now, just recently found that the sigrok people have introduced smuview.
    https://www.eevblog.com/forum/projects/smuview-a-sigrok-gui-for-power-supplies-multimeters-and-more/
    https://github.com/knarfS/smuview/releases               https://sigrok.org/wiki/SmuView
    I know some of us want stand alone smu system, but if it were as modular as practical, we assemble a system tailored to individual needs. I have tested the ADALM1000 with PixelPulse2, but am still interested in the potential of sigrok integration.
  • michaelkellett
    michaelkellett over 6 years ago in reply to jc2048
    I've read through the HP Journal article now - very interesting  - I'm going to have to hunt for schematics to find out how they did a current sense amplifier that could work with a 1G current sensing resistor !
    MK
    Jan Cumps over 6 years ago in reply to michaelkellett
    The high voltage current source paper is very interesting.
    Yes. And can be prototyped with lower voltages, just to get the feel of it.
    It's also a limited number of components, and that's good as a stepping stone to improve simulation experience.
  • michaelkellett
    Thanks.
    MK
  • jc2048
    Some more 'for information' or 'add to the reading list' stuff.
    This is the Wikipedia page for SMU
    https://en.wikipedia.org/wiki/Source_measure_unit
    it includes a link to an issue of the HP Journal devoted to the HP4145A Semiconductor Parameter Analyser. First article looks at the capabilities of the instrument, so good if you're trying to sort out your own spec. The second article includes a block diagram (simplified) of an SMU and lots of interesting stuff on the design side of it.
    http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1982-10.pdf
    On a different tack, this is an interesting take on the Howland.
    http://www.ti.com/lit/pdf/slyy054
    • Vote Up +5 Vote Down
