Test & Tools
Test & Tools
Blog Mitutoyo 530-122 Vernier Caliper
  • Author Author: javagoza
  • Date Created: 8 Mar 2022 10:58 PM Date Created
  • Views 4848 views
  • Likes 14 likes
  • Comments 8 comments
  • vernier caliper
  • bluebot
  • caliper
javagoza
javagoza
8 Mar 2022
I was selected as one of the winners for the giveaway in the Industrial Robotics quiz community.element14.com/.../industrial-robotics-quiz
The giveaway is a Vernier Caliper and it arrived at my office today. As soon as I got home I started trying it out.
It is a Mitutoyo 530-122 Vernier Caliper. It is a high accuracy model: ±0.03mm. It has metric scale
Unboxing
It comes inside a cardboard box.
With a plastic cover and instructions for use. Use cases and how to read the measurements with the maximum precision of the tool
Can measure outside and inside diameter (OD and ID), depth, and steps. Range 0 - 150mm
Roadtest
I'm testing it by making a 3D model of the blue boogie bot from element14 although I don't need that much precision for this task. It's really comfortable.
It is not a light caliber, the weight is noticeable and it is appreciated when having it in your hand. It is very well balanced and handles very well with the right hand.
It is very simple, easy to read, I can do the readings well without the need for close-up glasses or a magnifying glass.
The numbers and lines have very good definition, are very easy to read and have a sensational contrast. The ruled surface is glare-free and looks good from any angle.
It has a metric scale which is what I am used to using. It also has a very useful clamping screw for forgetful people like me.
Thank you for this excellent gift, it will always be close at hand on the desk.
  • jc2048
    jc2048 over 4 years ago
    Very nice prize. You're already putting them to good use.
    These are the two I have to hand.
    At work, we used to use Mitutoyo, but for my own use I couldn't justify the cost so ended up buying the metal ones at the bottom of the picture. These were apparently German made, though there's no branding on them.
    The plastic ones came from the cover of one of the UK electronic trade publications back in the 1990s or early 2000s (either Electronics Weekly or Electronics Times). There was a short-lived fad for giving away promotional items like this. These must have been sponsored by Anglia, who are a component distributor. They're surprisingly good for injection-moulded plastic.
  • jc2048
