Test & Tools
Test & Tools
Blog Mitutoyo 530-122 Vernier Caliper
  • Author Author: javagoza
  • Date Created: 8 Mar 2022 10:58 PM Date Created
  • Views 4844 views
  • Likes 14 likes
  • Comments 8 comments
  • vernier caliper
  • bluebot
  • caliper
javagoza
javagoza
8 Mar 2022
I was selected as one of the winners for the giveaway in the Industrial Robotics quiz community.element14.com/.../industrial-robotics-quiz
The giveaway is a Vernier Caliper and it arrived at my office today. As soon as I got home I started trying it out.
It is a Mitutoyo 530-122 Vernier Caliper. It is a high accuracy model: ±0.03mm. It has metric scale
Unboxing
It comes inside a cardboard box.
With a plastic cover and instructions for use. Use cases and how to read the measurements with the maximum precision of the tool
Can measure outside and inside diameter (OD and ID), depth, and steps. Range 0 - 150mm
Roadtest
I'm testing it by making a 3D model of the blue boogie bot from element14 although I don't need that much precision for this task. It's really comfortable.
It is not a light caliber, the weight is noticeable and it is appreciated when having it in your hand. It is very well balanced and handles very well with the right hand.
It is very simple, easy to read, I can do the readings well without the need for close-up glasses or a magnifying glass.
The numbers and lines have very good definition, are very easy to read and have a sensational contrast. The ruled surface is glare-free and looks good from any angle.
It has a metric scale which is what I am used to using. It also has a very useful clamping screw for forgetful people like me.
Thank you for this excellent gift, it will always be close at hand on the desk.
  • Andrew J
    Andrew J over 4 years ago
    Nice.  I looked at buying a Mitutoyo but ended up with a Duratool because I couldn’t really justify the cost.  It’s ok actually instructions are rubbish and I had to turn to internet.  Now you need a matching micrometer to go with it.
  • javagoza
    javagoza over 4 years ago in reply to Andrew J
    Yes, the micrometer is another gadget on the wish list along with a protractor.
    In the case of the protractor, I am totally lost, the price and type variations are huge and I don't know very well which one I would need, if I need any.
  • javagoza
