Test & Tools
Test & Tools
Blog Pico SCPI labLib now has configurable USB IDs
  • Date Created: 13 Mar 2026 3:22 PM Date Created
  • Views 453 views
  • Likes 11 likes
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • scpi
  • labtool
13 Mar 2026
Michael Stoops submitted pull requests to make a set of USB parameters configurable in your CMake file.
What USB IDs can be configured?
  • USB_VID
  • USB_PID
  • USB_MANUFACTURER
  • USB_PRODUCT
  • USB_SERIALNUMBER
  • FW_VER_BCD
  • FW_VER_STR
Before this new functionality was introduced, these attributes were defined in the LabLib source code. They had the same values as those of the Pico SDK examples.
When you want to commercialise a device, you need to set those to IDs that you license from the USB.org, and to your internal IDs.
In the past, you needed to alter LabLib's source. You can now define these, in the build file (or from the command line).
Setting the IDs
In your CMake config file (example from LabTool), you can add a section with the defines.
# set the USB IDs for this device
target_compile_definitions(${CMAKE_PROJECT_NAME} PRIVATE
        USB_VID=0xCafe
        USB_PID=0x4000
        USB_MANUFACTURER=0x01
        USB_PRODUCT=0x02
        USB_SERIALNUMBER=0x03
        FW_VER_BCD=0x0100
        FW_VER_STR="01.00"
If you don't define (some of) those, the initial example values from the Pico SDK are used.
link to all posts
    shabaz 7 months ago
    That's very useful!
    I'm still using this software in my bench supply, which didn't have SCPI prigrammability, but now does!
    shabaz 7 months ago
    That's very useful!
