Test & Tools
Test & Tools
Blog Progress will be slow, but I'm working on psychoacoustic masking with the Agilent 33622A
  • Author Author: Instructorman
  • Date Created: 30 Jun 2014 5:52 PM Date Created
  • Views 1283 views
  • Comments 6 comments
  • audio
  • 33622a
  • psychoacoustic
  • masking
  • steganography
  • agilent
Instructorman
Instructorman
30 Jun 2014
After making an initial post about my research plans for psychoacoustic masking and audio steganography using the Agilent 33622A, I left for a month long trip to Europe and Iceland.  I'm back now with plenty of interesting travel experiences and a lot of bills to pay.  I am also back to full time work and we are starting undertaking major house renovations - including the addition of a purpose built electronics lab space!
I will be busy, but I'm moving forward on the psychoacoustic research.  To make measurements of acoustic audio signals I will purchase a good USB microphone.  My preference right now is the Blue Yeti microphone.  The Blue Yeti gets good reviews and is reasonably priced, plus I can use it to improve the audio quality on any future video clips I produce.
To analyse the spectrum of acoustic audio signals sensed by the microphone I'll need audio spectral analysis software.  The spectrum analyser in the MDO4104-3 only goes down to 50 kHz which is well above the top end of human hearing.  The newer MDO400B series extend the spectrum analysis down to 9 kHz, which is better, but still misses a huge swath of human hearing.  So, to analyse signals in the human hearing range, optimally 20 Hz to 20 kHz, I'm looking for a cheap or free audio spectrum analysis package.  At the moment I'm leaning toward WavePad or TrueRTA.
Does anyone have any experience with any of these products (Blue Yeti microphone, WavePad or TrueRTA), or have recommendations for other microphones and/or audio spectral analysis tools?
In my previous post I was unclear about the difference between psychoacoustic masking and audio steganography.  The difference has clarified somewhat in my mind as follows:  Psychoacoustic masking is a human auditory system phenomenon that prevents humans from perceiving audio content under specific conditions of amplitude, duration and frequency proximity to other content.  Audio steganography refers to the techniques used to purposefully embed covert data within an audio transmission by exploiting psychoacoustic masking.  As mentioned in the first blog entry on this topic, both seem to require credulity to accept as fact.  Well, there is good evidence that both work well and are exploited on a full scale commercial basis by broadcast media.  Start by reading this short article which describes the use of psychoacoustic masking by radio stations that use the BBM audience monitoring system. There are plenty of other articles and papers on both topics available on the web through your favorite search engine.
Once the microphone and audio spectrum analysis pieces arrive, I'll start making some preliminary measurements and post the results here.
    I too am searching for similar audio analysis capabilities for low-noise testing of audio devices.  Although I can't offer solid advice on analysis software since I haven't picked one yet, I have done a bit of reading on the matter...
    If you haven't seen this already, check out Pete Millet's work (Soundcard Interface) with audio tester (audioTester). Only reason I'm shying away from this is because I'm trying to stay Mac based for audio testing due to the lack of necessity for complicated drivers.
    Also, your ADC will limit the accuracy and precision of your results.  The Blue Yeti isn't bad but consider another flat response mic combined with this preamp:  Product: UH-7000 | TASCAM
    Might be more than you intended to spend but the unit has incredible specs!  That Tascam will be my next purchase, along with software and a buffer for higher voltage testing.
    Something else to look at, if you have a descent bench meter with a good sample rate:  Using a DMM as a Low Frequency Analyzer
    Just need to interface the microphone to it.
    Don't have too much fun!
    MIke
  • Instructorman
    Instructorman over 12 years ago in reply to e14 Contributor
    Thanks for the suggestions Mike!
    Pete Millet's work is more involved than I'm willing to get into right now, but it looked interesting.  The TASCAM UH-7000 looked perfect until I saw the price.  Even discounted heavily at Amazon it came to more than $500.  I am looking at quality preamps, but I hope to keep the cost to less than half that.  My results may suffer a bit, but I'm just experimenting to learn at this point.
    The Agilent article on using a DMM to capture data for low frequency analysis is great!  I think I will give the ideas in that article a try.  I have a real good 6 1/2 digit meter with LXI web interface, so the article is quite applicable.
    Great links Mike, thanks again - and I will try not to have too much fun.
  • Instructorman
    e14 Contributor over 12 years ago in reply to Instructorman
    Glad I was able to help.
    I experimented with the Excel FFT method from the Agilent article and it worked surprisingly well.  Only issues I had was my 34461A's sample rate, limited at 0.02 PLC, missed harmonics from the 1KHz signal I tested with.
    Please post back with results if you can - I'd like to know what you get.
    Mike
