Test & Tools
Test & Tools
Blog PST.. Release 5 for the Pico SCPI labTool firmware (experimental functionality release): what's new?
  • Date Created: 15 Oct 2023 11:20 AM Date Created
  • Views 987 views
  • Likes 9 likes
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • labview
  • scpi
15 Oct 2023
The Pico SCPI labTool (PST) allows you to connect your PC to equipment to control and monitor all sorts of things. It runs on a Raspberry Pico.
In this post: new functionality available in the Release 5.
What's new?
This release adds experimental functionality.
Release 5 adds these new SCPI functions:
IEEE 488.2 service request support instrument can notify host based on events in the status byte
Other functionality added:
unit tests tests for service request added
More info on the experimental functionality:
 PST.. Experimental event / trigger support for Pico SCPI labTool - 6: Service Request from Instrument to LabVIEW flow
PST.. Experimental event / trigger support for Pico SCPI labTool - 7: Test Service Request from Instrument to LabVIEW flow
How to get the software (binary included)
check this post for a "how to install firmware and run the first LabVIEW process" video.
download link info
Pico firmware backwards compatible with previous versions. includes the .uf2 file to program your Pico right away
LabVIEW driver backwards compatible with previous versions. driver blocks for new functionality and extra examples
LabVIEW
This version includes LabVIEW example for the Service Request functionality.
link to all posts
    Jan Cumps over 3 years ago in reply to rsc
    I've been thinking about versioning, and what should change when cutting a new release.
    • should the *IDN? report a different version?
    • should the LabVIEW driver check for it?
      give a warning when driver and firmware don't match?
      fail if they don't match?
      give the flow designer the option to check for firmware version or ignore it?
    • things we haven't considered yet
    At this moment, the .uf2 is a little gesture for those that don't like to play with the sources. To lower the entry path.
    Playing with the sources and let the community develop features was the raison d'être.
    The rest is being worked on as an afterthought Slight smile.
  • rsc
    rsc over 3 years ago
    Now that you have released multiple revisions, it would be helpful for version tracking to have the revision number in the filename.
    pico_scpi_usbtmc_labtool.uf2 could be pico_scpi_usbtmc_labtool_R5.uf2
    Scott
