Test & Tools
Test & Tools
Blog PST.. Release 7.1 for the Pico SCPI labTool firmware: what's new?
  • Date Created: 27 Oct 2023 7:21 PM Date Created
  • Views 2625 views
  • Likes 8 likes
  • Comments 10 comments
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • labview
  • scpi
27 Oct 2023
The Pico SCPI labTool (PST) allows you to connect your PC to equipment to control and monitor all sorts of things. It runs on a Raspberry Pico.
In this post: new functionality available in the Release 7.1.
What's new?
Release 7 firmware makes it simpler for instrument developers to start a new project:
SCPI-LIB embedded in the project The Pico SCPI labLib (PSL) now has the SCPI-LIB as a submodule. It's no longer needed to download that lib's sources separately.
The SCPI_LIB_PATH environment is deprecated.
SCPI LIB build is handled by the PSL. It's no longer required to handle the sources build or manage the includes in the firmware app project.
SCPI terminator character configurable (7.1) The app used the SCPI-LIB default CRLF. The setting can now be changes in the application. PST set to LF only (like Keithley, Rigol, BT)
SCPI identifier with Pico unique id (7.1) The serial number in the PST identifier returns the Pico unique id (was: empty)
python unit test updates (7.1) Race condition in Service Request solved.
Moves on when Service request not invoked after 5 seconds
Adapted the SCPI identifier test (for terminator character and serial number)
The LabVIEW release adds 1 example:
How to get the software
download link info
Pico firmware backwards compatible with previous versions. includes the .uf2 file to program your Pico right away
LabVIEW driver backwards compatible with previous versions. driver blocks for new functionality and extra examples
New LabVIEW examples
You can run all examples with a Pico programmed with the PST firmware.
  • Sample High Resolution Analogue signals, contributed by taifur .
    From Solar Home System Monitoring using LabVIEW & Raspberry Pi Pico
link to all posts
    Jan Cumps over 2 years ago
    Also the SQR / interrupt functionality works well under Pico SDK 2.0. All good.
    I'm validating compatibility with pico c/c++ sdk
    I've tested all but the service request part, and there is no regression. That covers majority of the use cases. Tomorrow I'll set up a SQR test.
    Jan Cumps over 2 years ago in reply to Andrew J
    There is definitely the possibility to make better examples. I'm following what Keithley does mostly. Not the best practices for a sturdy flow. But on the other hand simpler to follow the core flow.
    I should improve some of the driver blocks though. The "time-out-swallow" part in the Initialize VI, is a remnant from a previous instrument I designed.
    It's so long ago that I can't remember if it had to do with TCPIP or USB-Serial issues. But it should not be in this driver's process.
    I think I should revisit the driver blocks when I have quality time, and check them off with the latest template examples from LabVIEW. That's where they were initially based on (many moons ago).
  • Andrew J
    Andrew J over 2 years ago in reply to Jan Cumps
    This is what I was thinking:
    Updated for  firmware 7.1:
    • SCPI terminator character configurable (7.1)
    • SCPI identifier with Pico unique id (7.1)
    • python unit test updates (7.1)
    LabVIEW driver isn't updated in this minor version.
