Test & Tools
Test & Tools
Blog Silicon Solder Mat
  • Date Created: 6 Feb 2021 4:39 PM Date Created
  • Views 6055 views
  • Likes 14 likes
  • Comments 47 comments
Silicon Solder Mat
6 Feb 2021
I purchased a silicon solder mat today, when I was in the electronics shop to pick up my order.
I use an antistatic mat as a generic work area, and prefer to keep that tidy. That mat can take an accidental touch of a hot iron, but it's not intended for that.
The silicon solder mat (from Velleman - Buy Belgian!) is heat resistant, up to 500° C.
Flexible and can be cleaned in a kitchen sink. It returns back to its original form.
Total size 45 x 30 cm. Work area without covering anything is approx. 40 * 28. It costed 20 €.
One of the biggest advantages for me is that it's easy to pick up and stow away. My lab is used as office, diner table and lab bench, depending on the time of day.
I prefer to have a reasonable clean desk. I remove instruments and projects when I use the desk as home office. And vice versa.
I'll report back in a while how the thing behaves in the real world. If I'm happy with the purchase or regret it.
  • ntewinkel
    ntewinkel over 5 years ago in reply to Jan Cumps +9
    Jan Cumps wrote: Mine has Velleman printed on it and that is better ! These would actually make great element14 swag. It's already the right colour too... just need some orange printing added. Velleman…
  • 14rhb
    14rhb over 5 years ago +7
    Hi Jan Cumps , I've the same mat, as you already ellude to, they are great for keeping the solder 'mess' in one place and I don't think you'll regret your purchase I bought my one to save me the embarassment…
  • ralphjy
    ralphjy over 5 years ago +7
    I use a smaller one - 35 x 25 cm, somewhat thinner (3.5mm) and without magnets. It works really well and is the perfect size for the type of soldering that I do. It was $8 from Amazon.
    Jan Cumps over 5 years ago in reply to cstanton
    cstanton  wrote:
    Is silicone prone to static anyway?
    The internet says they add a component (graphene) during manufacturing to make it slightly conductive
  • cstanton
    cstanton over 5 years ago in reply to Jan Cumps
    Jan Cumps over 5 years ago in reply to gordonmx
    The box says it's ESD safe.
  • gordonmx
    gordonmx over 5 years ago
    Correct me if I'm wrong, but I don't believe these mats are anti-static which is a concern.  I noticed that they don't seem to have a grounding contact.  There may be an static dissipative spray, like the film on a "pink" or "blue" poly bag that can be used.
    Stay Safe, Stay Well,
    Gordon
    dougw over 5 years ago in reply to ntewinkel
    I have several different vises I use to hold things I am soldering. The fine-work card-vise (which is flat and heavy) sits under a stereo microscope and needs to slide smoothly around so I can position the work properly under the microscope. The microscope is suspended from a cantilever so no part of it touches the bench surface, but it does not move. Additionally, I have brace pads for my wrists to keep them steady - those braces need to slide as well. A mat wouldn't make sense for that workflow.
    I do have the inklings of a card holder design that allows easy positioning of work under a microscope, but that is still in the daydreaming project bucket.
