Test & Tools
Test & Tools
Blog Silicon Solder Mat
  • Date Created: 6 Feb 2021 4:39 PM Date Created
  • Views 6062 views
  • Likes 14 likes
  • Comments 47 comments
Silicon Solder Mat
6 Feb 2021
I purchased a silicon solder mat today, when I was in the electronics shop to pick up my order.
I use an antistatic mat as a generic work area, and prefer to keep that tidy. That mat can take an accidental touch of a hot iron, but it's not intended for that.
The silicon solder mat (from Velleman - Buy Belgian!) is heat resistant, up to 500° C.
Flexible and can be cleaned in a kitchen sink. It returns back to its original form.
Total size 45 x 30 cm. Work area without covering anything is approx. 40 * 28. It costed 20 €.
One of the biggest advantages for me is that it's easy to pick up and stow away. My lab is used as office, diner table and lab bench, depending on the time of day.
I prefer to have a reasonable clean desk. I remove instruments and projects when I use the desk as home office. And vice versa.
I'll report back in a while how the thing behaves in the real world. If I'm happy with the purchase or regret it.
  • ntewinkel
    ntewinkel over 5 years ago in reply to Jan Cumps +9
    Jan Cumps wrote: Mine has Velleman printed on it and that is better ! These would actually make great element14 swag. It's already the right colour too... just need some orange printing added. Velleman…
  • 14rhb
    14rhb over 5 years ago +7
    Hi Jan Cumps , I've the same mat, as you already ellude to, they are great for keeping the solder 'mess' in one place and I don't think you'll regret your purchase I bought my one to save me the embarassment…
  • ralphjy
    ralphjy over 5 years ago +7
    I use a smaller one - 35 x 25 cm, somewhat thinner (3.5mm) and without magnets. It works really well and is the perfect size for the type of soldering that I do. It was $8 from Amazon.
  • gordonmx
    gordonmx over 5 years ago
    Correct me if I'm wrong, but I don't believe these mats are anti-static which is a concern.  I noticed that they don't seem to have a grounding contact.  There may be an static dissipative spray, like the film on a "pink" or "blue" poly bag that can be used.
    Stay Safe, Stay Well,
    Gordon
  • gordonmx
    Gordon
    Jan Cumps over 5 years ago in reply to gordonmx
    The box says it's ESD safe.
  • cstanton
    cstanton over 5 years ago in reply to Jan Cumps
    Is silicone prone to static anyway?
    Jan Cumps over 5 years ago in reply to cstanton
    The internet says they add a component (graphene) during manufacturing to make it slightly conductive
  • ntewinkel
    Yours came with a box!? Luxury!!
    dougw over 5 years ago in reply to cstanton
    Silicone without additives is a good insulator. The material probably will accept electrons so if you rub it (humans give up electrons) you would likely get "charged up".
    Since it is a good insulator, you probably couldn't discharge to it with a spark and it isn't as prone to give up electrons needed for such a spark.
    But if you get charged up by rubbing silicone you can discharge to any ground - with a spark.
    I'm not sure how adding graphene affects the tendency to transfer electrons through rubbing, but if the mat is slightly conductive and it is grounded, it may eventually bleed off (equalize) charge.
    I haven't tried this material - this is just speculative theory...
