Test & Tools
Test & Tools
Blog Silicon Solder Mat
  • Date Created: 6 Feb 2021 4:39 PM Date Created
  • Views 6088 views
  • Likes 14 likes
  • Comments 47 comments
Silicon Solder Mat
6 Feb 2021
I purchased a silicon solder mat today, when I was in the electronics shop to pick up my order.
I use an antistatic mat as a generic work area, and prefer to keep that tidy. That mat can take an accidental touch of a hot iron, but it's not intended for that.
The silicon solder mat (from Velleman - Buy Belgian!) is heat resistant, up to 500° C.
Flexible and can be cleaned in a kitchen sink. It returns back to its original form.
Total size 45 x 30 cm. Work area without covering anything is approx. 40 * 28. It costed 20 €.
One of the biggest advantages for me is that it's easy to pick up and stow away. My lab is used as office, diner table and lab bench, depending on the time of day.
I prefer to have a reasonable clean desk. I remove instruments and projects when I use the desk as home office. And vice versa.
I'll report back in a while how the thing behaves in the real world. If I'm happy with the purchase or regret it.
  • ntewinkel
    ntewinkel over 5 years ago in reply to Jan Cumps +9
    Jan Cumps wrote: Mine has Velleman printed on it and that is better ! These would actually make great element14 swag. It's already the right colour too... just need some orange printing added. Velleman…
  • 14rhb
    14rhb over 5 years ago +7
    Hi Jan Cumps , I've the same mat, as you already ellude to, they are great for keeping the solder 'mess' in one place and I don't think you'll regret your purchase I bought my one to save me the embarassment…
  • ralphjy
    ralphjy over 5 years ago +7
    I use a smaller one - 35 x 25 cm, somewhat thinner (3.5mm) and without magnets. It works really well and is the perfect size for the type of soldering that I do. It was $8 from Amazon.
    Jan Cumps over 5 years ago in reply to neilk
    neilk  wrote:
    ...It's not as sophisticated as yours, but will meet my needs image...
    Knowing myself, I'll probably cut off the 3 annoying flaps off my mat as soon as the mortgage is payed.
  • neilk
    neilk over 5 years ago
    Mine has finally arrived. It's not as sophisticated as yours, but will meet my needs image
    It's about A4 sized.
    Neil
    • Vote Up +5 Vote Down
    Jan Cumps over 5 years ago in reply to geralds
    geralds  wrote:
    .... If I understand correctly, you put flux and tin paste on the pads, right? ..
    When I use paste, I don't use flux. Because it's mixed in the paste.
    I use flux for all other soldering activities.
    • when I place components with solder
    • when I use the heat gun to rework already soldered pads.
    I use lead free, and flux makes that an exercise that's gives good results.
    When I used leaded solder in the past, the resin flux in the core of the solder was enough.
  • 14rhb
    14rhb over 5 years ago in reply to geralds
    I like my mat because it contains all of the mess from board prototyping - snips of wire, trimmed solder ends, the odd 'butchered' component, bits I've desoldered, solder dregs, bits of used desoldering braid, flux splatter etc. I haven't found an issue with it wobbling as it sits quite firmly to my wooden bench surface. If anything I think the slight flex allows easier picking up of SMT parts vs. a solid surface where they do have a tendency to ping off image. I don't really use the magnetic areas - maybe they would be nice for  watch repair job - but then again they are likely brass screws!
    Once finished I can roll the mat and empty it into my electronic waste bin. Having very little space available, the bench is now clear to for fine woodwork projects, painting etc.
  • geralds
    geralds over 5 years ago in reply to Jan Cumps
    If you don't need the ridges and pockets (and I think they aren't essential), then a flat mat (or a flat one with a little ridge to keep flux from flowing off) would be certainly as good. And cheaper.
    "Flux" - this is very interesting.
    Then such a mat is a good choice.
    Then the bench will not so grimy.
