Test & Tools
Test & Tools
Blog Soldering Irons
  • Author Author: fluxcap
  • Date Created: 4 May 2018 9:10 PM Date Created
  • Views 3644 views
  • Comments 20 comments
  • soldering station
  • soldering iron
  • soldering
Soldering Irons
fluxcap
fluxcap
4 May 2018
I'm looking to step up my soldering game. I've seen the relatively new intergrated heating element into the soldering iron tip, like the JBC stations. Does anyone know a budget version that uses the same tech?
    jw0752 over 8 years ago +4
    Hi Jade, Here is a great soldering iron that was given to me by a good friend. I have been using it every day for about a year and it is still on the first tip. You can set the temperature anywhere you…
    shabaz over 8 years ago +3
    Hi Jade, I've not used it myself, but we specified Metcal PS-900 for a few sites, no complaints so far. It is fairly low cost. It uses Metcal's own system, which is like a competitive technology to other…
  • fluxcap
    fluxcap over 8 years ago in reply to genebren +3
    I looked at it and it seems to be a good choice only that your counting on the smartheat thing to adjust for the temp. I'd rather be able to control it. Also if you know of any really good old tech soldering…
  • fluxcap
    Thank you guys so much for being helpful!!!!
  • fluxcap
  • michaelkellett
    michaelkellett over 8 years ago in reply to fluxcap
    I'm using an ERSA iCON pico (£151 from Farnell) for surface mount work and I'm please with it (I have two with different sized bits in one small for 0402 - 0805 and one hollow for 0.5mm pitch TQFP).
    I'm very happy with them (and they do have real temperature control with numbers and turn themselves down after a while so forgetting to turn them off doesn't cost you a new bit (or a fire))
    MK
