Test & Tools
Test & Tools
Blog The Modular Bench Power Supply ++, Putting it all together, the bare bones
  • Author Author: Robert Peter Oakes
  • Date Created: 4 Dec 2014 5:45 AM Date Created
  • Views 4792 views
  • Comments 16 comments
  • bench
  • tutorials
  • modular
  • supply
  • power
Robert Peter Oakes
Robert Peter Oakes
4 Dec 2014
I will be putting together the video this week end to go with this schematic but I thought i would share this with you in the mean time
VCC can be as much as 40V (I was powering the test circuit on a breadboard with a bench PSU for now set to 30V, my psu max)
In the video I will be reviewing the behaviour of this circuit as well as Identifying a few pitfalls (Nothing serious and probably acceptable for a basic PSU but we do want to evaluate where we can improve on things
If you think you know the potential issues, please post and we will compare notes at the weekend image (There are two primary ones)
Here is the video that describes and goes through some basic tests of this circuit
Enjoy, again, a little detailed so its is about an hour long
I will be adding notes etc in the next few days
    Hi
    I built this on a bread board seems very good need to add a meter to it
    what is the number of the Vishay four wire sense resistor that you used I cant find it I used a 1% .100ohm  5 watt sense resistor ,seems ok
    Garry
    Hi
    Garry
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to e14 Contributor
    What is important about the sense resistor is the ability to know its value and that it is stable
    a .1ohm 5W is perfect, you say it is a sense resistor, do you mean it is 4 terminal ? (Kelvin Connections)
    the ones I have are Visha Bulk Metal
    VPG - Foil Resistors - FPR 4-T220 T2211
    and
    VPG - Foil Resistors - FHR 4-3825 to 4618
    My power sense FPR is also 1% but I can measure it to better than that and as it is very stable it will remain accurate with the measured value
    e14 Contributor over 10 years ago in reply to Robert Peter Oakes
    I could not see the Vishay four terminal one  at farnell , I did not have the number at the time
    so I bought this one , MULTICOMP  MC14721  Through Hole Current Sense Resistor, MC Series, 0.1 ohm, 5 W, ± 1%, Axial Leaded, Wirewound
    it does the job
    garry
