Test & Tools
Test & Tools
Forum The opposite of a ten turn potentiometer?
  • Replies 11 replies
  • Subscribers 386 subscribers
  • Views 2646 views
supper_slash
supper_slash over 10 years ago
I need a solution for a potentiometer that goes from 0-100 in an eight of a turn.
Think of a lever that is testing the thickness of something.  And every second or so the reading is taken and logged into an Arduino.
I have used an Arduino to read pot's before,but I have never only had to read from(12 o'clock, to 2 o'clock) before with high sensitivity.
I was thinking of using a GEAR amplification to make a regular pot work if I must, but it would take a very large amount of space, so I am trying to think of another solution.
    0 jw0752 over 10 years ago
    Hi Lupe
    Why don't you map the 0-100 onto the change in resistance as a conventional potentiometer rotates through the arc that you describe?
  • supper_slash
    0 supper_slash over 10 years ago
    That will be what I need to try next. To see if It will have enuff resolution.
    0 dougw over 10 years ago
    To get a full scale reading, you may need to amplify the output of the pot or use a higher voltage on the pot.
    If you do use a higher voltage across the pot, you may need to protect the arduino input with a Schottky diode to the arduino rail.
    0 michaelkellett over 10 years ago
    Depending on the application you might get away with this, it's more usual to use a different kind of sensor for measuring small displacements.
    You can use strain gauges on a springy metal arm or LVDT sensors, or perhaps a rotational sensor designed to work over small angles.
    If you tell us what you are trying to measure it would be possible to advise you better.
  • supper_slash
    0 supper_slash over 10 years ago in reply to michaelkellett
    I have 2 projects in the works for this application.
    1. A volume pedal type device that the pot will need to be mounted at the pivot point. {As it is now I am not happy with my design that uses a vertical runner to turn a gear on a standard POT.}Strip Gear.
      The above image shows the parts used in the current designs in the foot pedals that I am looking to replace. I am hoping to simply place a POT AT the pivot point in this design.
      Pedal design
    2. A gauging system for my filament on my 3-D printer. The Idea is to have a lever with a roller at the end of it amplify the thickness of the pinched filament to a mounted POT. That pot will send the readings every 10 seconds or so to a Microcontroller for data logging.
      lever
      POT on the left, roller and filament on the right. So small changes in the filament  effect large changes in the POT.
  • D_Hersey
    0 D_Hersey over 10 years ago
    You might consider a slide pot in the first case.  You can get an accelerometer to act as a tilt sensor 'cause gravity.
    0 michaelkellett over 10 years ago in reply to supper_slash
    You won't do better than the pot with rack and pinion for the foot pedal, at least not without a lot of complication.
    For the filament thickness there are loads of options - how much are prepared to spend and how much time can you put into messing about.
    Look here for some ideas:
    https://www.aliexpress.com/wholesale?SearchText=displacement+sensor&initiative_id=RS_20160930091159
    good range of prices - from about £10 to over £1000
  • D_Hersey
    You can use a wedge of high Al material moving in the gap between a magnet and a linear hall-effect sensor for the foot pedal
  • D_Hersey
    If your foot pedal has a return spring you can measure its changes in inductance.  Ti has a nice, cheap kit for this.
  • D_Hersey
    Even simpler than a rack-and-pinion would be a very low-pitch screw that would turn a rotary pot.
