Test & Tools
Test & Tools
Forum Power Cables - Where to get nice ones
  • Replies 15 replies
  • Answers 11 answers
  • Subscribers 386 subscribers
  • Views 3353 views
  • banana plug
  • power supply
  • alligator clip
  • cables
  • flexible
kas.lewis
kas.lewis over 8 years ago
Hello All,
I'm looking for power cables to be used with my various power supplies. I need one end to have a banana connector and the second end to have an alligator clip. The reason I'm asking is because there are so many cables out there (even when doing a search on farnell/newark). I am preferably looking for one with silicone insulation. The reason I'm looking for this is I would really like a cable that is very flexible and can easily weave its way around my working space.
Any suggestions or even better product numbers would be great.
Kas
    genebren over 8 years ago +5 suggested
    Kas, I like these a lot (with ez-hook ends): http://www.newark.com/pomona/3782-36-2/test-lead-red-914-4mm-60v-5a/dp/10M4287?st=3782-36 http://www.newark.com/pomona/3782-36-0/test-lead-black-914-4mm-60v…
    shabaz over 8 years ago +5 suggested
    Hi Kas, I was going to stick this photo in a discussion earlier in the week, but didn't get around to it - it's possibly an alternative solution for some scenarios. These are really low-cost banana plug…
    jw0752 over 8 years ago +5 suggested
    Hi Kas, I like to make my own also. I like to use the Pomona Hookup wire which is available in Red or Black. http://www.newark.com/w/c/cable-wire-cable-assemblies/hook-up-wire-single-conductor/prl/results…
  • kas.lewis
    0 kas.lewis over 8 years ago
    Thank you everyone for your response and suggestions. I will use all these answers to come up with something custom that works best for me.
    Kas
    0 jw0752 over 8 years ago in reply to kas.lewis
    Hi Kas,
    Thanks for the heads up on the incorrect link that I provided. I have corrected it and it should take you to the right place now. The Pomona wire is excellent and I use a lot of it to make patch cables as well as meter probe wires.
    Here it is again incase you don't want to return to my previous post.
    http://www.newark.com/w/c/cable-wire-cable-assemblies/hook-up-wire-single-conductor/prl/results?st=Pomona+wire
    0 genebren over 8 years ago in reply to kas.lewis
    For cable flexibility, nothing beats the silicone rubber cables that jw0752 mentioned in his reply below (Pomona Hookup wire).
    Gene
  • abrain
    0 abrain over 8 years ago in reply to kas.lewis
    Just in case, note the 42V rating on those Wagos.... I’ve used them significantly higher without issue before remembering how I’d hooked things up. I’ve given quite a few of those away to people who have seen and loved them, but I know there’s at least a handful in the top of my toolbox ready for today’s mission!
    A
  • kas.lewis
    I received my order of Pomona wire today (took me awhile to actually order it) and I must say it could not be more like a dead fish if I wanted it to be. the wires are so limp it's amazing. I look forward to building my amazingly flexible cables and using them.
    Finally some awesome cables that I will be more than happy to use.
    Kas
