Test & Tools
Test & Tools
Forum Adjustable power supply
  • Subscribers 385 subscribers
  • Views 765 views
  • test
Hi, does anyone know how does an adjustable DC power supply usually get their energy source? Is it connected to an electrical socket like a normal electrical appliance?
And i have another question: does it have an inbuilt rectifier, or does it require an additional rectifier to function?
    0 dougw over 12 years ago
    Hi Naziah,
    Typically an adjustable DC power supply gets its power from a standard AC wall socket, but you can get some that run off DC batteries.
    The ones that run on AC always have an internal rectifier. Usually the DC output is isolated from the AC input, but not always - this should be checked.
    Some of them have a third connection for chassis ground which may be connected to the ground in the AC wall socket.
    0 e14 Contributor over 12 years ago in reply to dougw
    Thanks Douglas! You answer is helpful (:
    A power adapter always contains the plug for the wall outlet for source energy. Most of electrical equipment get energy source from AC wall socket.
