Test & Tools
Test & Tools
Forum Advice in oscilloscope needs
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 386 subscribers
  • Views 1969 views
  • oscilloscope
  • logic_analyzer
  • advice
Hi Guys,
Oscilloscope noob here! I am doing some various tinkering that I think I could use an oscilloscope for and I am wondering if the DS201 will do what I need. I have a bunch of old Commodore 64s that I would like to try and fix so I would like to check that the clock outputs from the various chips are working. Will the Nano be ok for this? Looking at thew review and the specs for the C64 I suspect not?
My other project is I am trying to interface a six button Sega Megadrive controller to a Arduino Pro Micro using the sketch from here: Sega Genesis controllers and Arduino revisited | Jon Thysell
However it is only working in 3 button mode yet the controller appears to work ok with a real megadrive so I want to be able to look at and measure the pulsed sequences that are sent to the controller so I can emulate them exactly with the Arduino. The pulse widths are around 20 microsecs but could be less. So do you think the Nano 201 will be able to show me what the exactly series of pulses being generated by the Megadrive are?
Obviously these are just hobbies so I am not looking to spend a lot of money but if it isnt going to be able to do what I need then I will look elsewhere maybe a second hand something? I have also thought that the Hantek 6022BE might be a better option perhaps?
Edit: Also I am wondering if what would be better for what i am wanting to do would be a logic analyser?
Thanks for the advice,
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to e14 Contributor +1
    It would be at its limits at 8Mhz because its sampling is only 48Mhz so even a 4* overhead would barly give you 10Mhz An alternate option is to purchase an older analogue scope. there are very good and…
    Jan Cumps over 11 years ago in reply to e14 Contributor +1
    It's okay to buy a second hand analog scope. But It's also okay to buy a 2nd hand digital one. Since Rigol released their new DSxx4Z series, the price of second hand DS10x2's has gone down - almost to…
  • peterjcs23
    0 peterjcs23 over 11 years ago
    The DS201 has a bandwidth of 200kHz and clocks are likely to be much higher frequency. Better to check out the Pico range of scopes that run on a PC. Some of them have logic analyser functions. But you need a scope capable of measuring signals at least as fast as the clocks you're interested in.
    0 Robert Peter Oakes over 11 years ago
    I would go for a low cost but full oscilloscope
    the DS102 has only DC coupling so can not look at small signals with large DC offset
    limited to 200Khz at best so no good for uController clock pins and the like which often run in the Mhz ranges
    would not handle high speed I2C, SPI signals
    for a similar cost you can get a 2 channel scope with a full screen (4-7") depending on model and maker and it will with perhaps a 50Mhz bandwidth (Not sample rate, but actual bandwidth) and this will handle the common microcontrollers etc.
    something like the following
    500$ :- TBS1000B-EDU Digital Storage Oscilloscope | Tektronix
    For 250$ ish you can get one of these that has receved alot of good reviews, check out Dave Jones blog (the EEVBlog)  Rigol DS1052E 50MHz Digital Oscope with 2 Channels, USB Storage Access, 1 GSa/sec sampling: Science Lab Oscilloscopes: A…
    Hope this helps
    Peter
    Thanks Peter and Peter!
    I am just a hobbyist so need to keep the price under $200AUD. As far as I can tell the C64 clock runs at 8Mhz so yes it would appear the DS201 probably wont fit the bill. The Hantech 6022BE claims to run at 20MHZ http://www.ebay.com.au/itm/Hantek-6022BE-PC-Based-USB-Digital-Storag-Oscilloscope-2-Channels-20MHz-48MSa-s-/231040792895?pt=LH_DefaultDomain_15&hash=item35cb1ab93f
    There is also this one near me 10MHz Oscilloscope With Probe *** Smith Q1803 Pickup From 4128 OR Post | eBay
    In Australia *** Smith was previously a local hobby electronics retailer.
    Indeed I am still wondering if a logic analyser would be better for me. I see this one similar to the first: http://www.ebay.com.au/itm/Hantek-6022BL-PC-Based-USB-Digital-Portable-Oscilloscope-16-CHs-Logic-Analyzer-/380925589837?pt=LH_DefaultDomain_15&hash=item58b0ef394d
    I know these are cheap and you get what you pay for but I wont need to use one very often and if I can use it to measure the pulse widths and series of pulses of the Megadrive I think that will be all I need.
    Thanks again for helping me out.
    edit: I am not sure how regular the signal for the megadrive controller repeats so a method to record the output so I can look back over it might be useful? I wondered if the USB/software based logic analyser might do this? need to look into this as well?
    0 Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    An alternate option is to purchase an older analogue scope. there are very good and can be had at quite a good price. Dave Jones of the EEVBlog is always saying this too so Im not alone in this opinion and in some respects this can provide a better learning experiance than a medocure but new digital one
    Just a thought
    0 e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    Thanks Peter,
    IT might be hard to come by anything decent though? The Q1803 I mentioned above was mentioned last year on eevblog and they said $100 was too much to pay. I found another a qc-1901 on eBay but on eevblog again they said it wasn't very good.
    So again I wonder if that hantek logic analyser might be ok for me? I have looked at the articles on the pros and cons of oscilloscope vs logic analyser and it isn't clear cut for me but since I am mainly intrested in low voltage digital signals...? What would be the downside for me with something like that? I often have my laptop on the desk programming arduinos so I don't mind having to hook up to that.
    thanks for any help, I just don't want to spend the money and find I can't see exactly the pulse train coming from the megadrive primarily and secondly the c64. I have a logic probe coming in the mail as well so I hope that will help with my diagnostics also.
    0 michaelkellett over 11 years ago in reply to e14 Contributor
    A logic analyser isn't much use if you don't have a scope - I would always get the scope first.
    You can get a 10MHz Pico scope with 2 channels for £79 but you need to buy probes separately which will take you to about £99.
    The Rigol DS1000E is £199 and about the cheapest almost decent real scope on the market.
    If it's the most you can afford the Hantek is useable (just) see review here: http://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/
    (Note: it claims 20MHz bandwidth and samples at 48MHz, the Pico has  a 10MHz bandwidth and samples at 200MHz - imagine representing a sine wave with 2.4 samples and decide which supplier is talking sense !)
    The ebay ones you linked looked pretty bad value - if you were local I'd sell you a 20MHz glass screen scope for £10 (if you told  a good story I'd give it to you since I got it off a skip (literally) 12 years ago). Try begging from local electronics places (if there are any).
    0 e14 Contributor over 11 years ago in reply to michaelkellett
    Thanks michael,
    I had seen that review previously and from that and your post I think i will give it a try. For $80 delivered (found a non eBay site in Australia) I can't go too far wrong I don't think. I think for my megadrive project with pulses at around 10 microseconds it should work fine? I also found a YouTube video of a guy repairing a commodore 64 using one so that is a good sign.
    i Will keep my eye out though on gumtree and eBay if any good second hand ones come up locally.
    If anyone else has any last thoughts (warnings!) I would appreciate it.
    Gavin...
    Beginners should always get analog 2-channel scope with 20MHz bandwidth atleast. No point to get expensive DSO, as a first scope, especially second-hand. I learned this the hard way. My first DSO broke, but my 20MHz analog still works.
    Actually, my analog scope is my only scope, because i can't afford a new one.
    0 Jan Cumps over 11 years ago in reply to e14 Contributor
    Since Rigol released their new DSxx4Z series, the price of second hand DS10x2's has gone down - almost to pocket money level.
    (I've sold my analog 20MHz scope, bought a 1052 with the money and still had some change left to go to the pub image ).
