Test & Tools
Test & Tools
Forum Top 6 Tools
  • Replies 60 replies
  • Subscribers 383 subscribers
  • Views 14044 views
  • favorite tools
Top 6 Tools
dougw
dougw over 4 years ago
All makers are into tools but which tools are their go-to tools. I tried to analyze which half dozen tools I use most often and came up with a slightly surprising list. Obviously it varies from project to project, but some tools get used consistently more than others. I think it will be interesting to discover what others use.
Which half dozen tools do you use the most?
Here are the ones I came up as my top 6 most used tools - they hint at how much time I spend on 3D printing:
Some notables didn't quite make the list - soldering iron, stereo microscope and power supply (mostly because I don't always use the same supply).
  • robogary
    robogary over 4 years ago +9
    My top tools are a gas grill, spatula , and tongs. Working, building, testing, and fixing stuff makes me hungry. An E14 cooler for drinks next to my lounge chair would make this scene complete :-)
  • colporteur
    colporteur over 4 years ago +7
    Two tools I would add to your list are round-nosed pliers and jeweler screwdrivers. The pliers are ideal for shaping wires and components. Especially for putting loops in the ends of wires. The screwdrivers…
  • fmilburn
    fmilburn over 4 years ago +6
    Maybe it isn’t considered a tool but I use my computer more than anything else - for research, design, documentation, coding, lab instrument display, and so on. Also for distraction from what I should…
    shabaz over 4 years ago in reply to baldengineer
    Not heard of blue tape before : ) but guessing it's similar to washi tape? I use it for marking up panels before drilling, and also labelling components... Pencil, and Edding 140 S pens write on it (and everything else! - they are permanently permanent.. don't know if they are available worldwide).
  • beacon_dave
    beacon_dave over 4 years ago in reply to shabaz
    Scotch blue Original roll of masking tape
  • aspork42
    aspork42 over 4 years ago
    Can I list my top 10 tools? What if they're all part of the same tool?
    This is my can't-leave-home-without-it tool. This is the Leatherman Wave multi-tool. I have four in my 'fleet' and use it multiple times per day. I can use it for all sorts of intended and un-intended uses. Opening packages from E14, un-sticking zippers on my kids' coats, cutting coat hangers, stripping wire, cutting [small] tree branches when the chainsaw gets stuck (actually happened). I can use it with industrial terminal blocks and industrial power supplies. Every time I'm without it, i feel naked. I upgraded (through E14) to the expansion bit set for interchangeable bits on the screwdriver. I wear it on my belt daily.
    shabaz over 4 years ago in reply to aspork42
    That looks so much more practical for engineers than a Swiss Army knife. With the SA knife it is almost guaranteed you'll accidentally cut yourself one time or another with the stiff blade they have, and need superhuman nails to pry out a tool without pain. Maybe it's just me though!
  • beacon_dave
    I think you might do yourself an injury just trying to fit it into your 'pocket'
    Wenger 'Giant' Swiss Army pocket knife
    • Vote Up +6 Vote Down
  • wolfgangfriedrich
    wolfgangfriedrich over 4 years ago in reply to beacon_dave
    Try closing the tools first. Joy
    dougw over 4 years ago in reply to beacon_dave
    That is good point about having a "self-correcting" excess. I have observed the phenomenon without considering that it might be a natural law.
    I tend to injure myself when trying to open the correct tool.. Cold sweat
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to dougw
    DITO!!! NEVER ENOUGH!!image
  • phoenixcomm
    imageCant name six or a dozen. I use too many tools, 5 or 6 are small pliers; needle nose, round, 90deg, 45deg most of them are EREM. My Metcal Solder Station, lots of small screwdrivers Torx, Philips, etc. my Dremel, and a whole lot more. Oh yes I can't leave home without my Tek 475A or my Fluke 113 DMM
    image image
