Test & Tools
Test & Tools
Forum Fuse /Power supply troubleshooting
  • Replies 19 replies
  • Subscribers 387 subscribers
  • Views 6321 views
gio_dude
gio_dude over 9 years ago
My friend at work built a 3d printer from a kit and his power supply went out. He said it made a pop noise and got no power from it. He ordered a new one already and gave me the old one and I would like to try and fix it.
Once I took it apart the first thing i saw was a fuse that looked blown. I got no continuity on the fuse from my multimeter. I unsoldered the fuse and the writing on it looks to be P5AL 250v or F5AL 250v.
1) is there anything else you guys can recommend me testing or looking for.
2) I found this on amazon it looks to be the right fuse but can I solder leads to it.
https://www.amazon.com/BUSHIBU-F5AL-Fast-Blow-Glass-Fuses/dp/B01NAQH2TB/ref=sr_1_2?s=industrial&ie=UTF8&qid=1496014763&sr=1-2&keywords=F5AL+250v
3) do you think I can put a holder on the PCB incase it blows again it would be easier to change. I attached a picture of where it was on the PCB.
    jw0752 over 9 years ago +5
    Hi Giovanni, If you want to solder leads on the new fuse here is a procedure that I have used. File each end of the new fuse so you can see brass. This makes the solder adhere better. Use a hot iron and…
    mcb1 over 9 years ago +5
    The supply pictured is a switchmode supply, and the fuse has definately gone bang. As jw0752 said it has lethal voltages and the first stage they rectify the mains voltage, filter it and then chop it to…
    jw0752 over 9 years ago in reply to gio_dude +5
    Hi Giovanni, Let's start with in circuit testing. Do you have an analog multimeter? I ask as it is easier to visually make these tests watching a needle than trying to interpret a digital display that…
  • gio_dude
    gio_dude over 9 years ago in reply to jw0752
    Thank you I was wondering about the glue that makes sense now
    I attached some pictures of readings and the bridge rectifier mine doesn't have a tilde (side ways S) it just says AC which makes sense since that is the symbol for AC.
    my multimeter isn't auto ranging and after today I'm considering upgrading it.
  • jc2048
    jc2048 over 9 years ago in reply to jw0752
    Giovanni is using the meter on the diode setting, so the reading is the forward voltage.
  • rachaelp
    rachaelp over 9 years ago in reply to gio_dude
    Giovanni Laucella wrote:
    Thank you everyone for you advise. I not sure I'm going to use this power supply again because I still don't trust my self yet with lethal voltages. I am in the USA so its 120v but still kind of scary.
    Hi Giovanni,
    Just for reference, even though you are in the US with "only" 120V, if you were working on an AC/DC converter that included power factor correction the nature of how the PFC works usually involves the voltage being boosted to much higher, so you could end up with voltages in the range of 400V on large capacitors so you are very right to be cautious when working on this type of circuit.
    Best Regards,
    Rachael
    jw0752 over 9 years ago in reply to jc2048
    Hi Jon,
    Good catch. After I turned off the computer and walked away it dawned on me that he was using the diode test and not the Ohmmeter. Always difficult to trouble shoot with limited access to info.
    Hi Giovanni,
    Based on your pictures it looks like the Bridge is OK. Just be sure you can get approximately .62 Volts from the plus to each of the AC and from the minus to each of the AC. The information I gave you before was based on the assumption that you were testing the diodes with the Ohm meter set on Rx1.
  • gio_dude
    Thank you everyone I will continue to test.
    Rachael I didn't know that, I will look more into PFC they sound interesting. this power supply has been sitting for a few months so that should help. Do you have any recomedations of what precations I should take or look out for.
  • rachaelp
    Rachael I didn't know that, I will look more into PFC they sound interesting. this power supply has been sitting for a few months so that should help. Do you have any recommendations of what precautions I should take or look out for.
    Hi Giovanni,
    There are quite a lot of interesting things to be learning about power supplies. Its a fascinating topic when you get into it image Unfortunately it's an area which is considered by a lot of people as a black art and they shy away from it, but when you start to look further into it, there's lots of fun to be had!
    If you are working on an PSU that is powered off, just make sure all the capacitors have been discharged so there can be no retained high voltages before you handle it and you should be fine. If in the future you are considering debugging a misbehaving power supply "live" then that's entirely different and you'll need more test equipment such as an isolation transformer (this helps with safety), an oscilloscope with high voltage differential probes, and possibly an AC/DC current probe. I'd not recommend attempting this until you are very familiar with how these power supplies work and know where all the dangerous bits are and have the knowledge and experience to be able tackle this more safely.
    Best Regards,
    Rachael
  • rachaelp
    A decent multimeter can make the world of difference to the success and enjoyment of this hobby, you don't have to spend a fortune on one, just make sure you get a reasonable brand one and not a cheap one, especially if you are doing any work on AC power supplies as the cheap ones that claim certain protection ratings on their inputs often really aren't designed well enough to actually adhere to those ratings and can be dangerous. You're probably already familiar with the EEVBlog but if not head over to the YouTube channel and look at some of Dave's videos on decent multimeters to get and ones to avoid. He even does a decent EEVBlog branded one now that he did in partnership with one of the multimeter manufacturers.
    Besides, even if your current one is fine, having more than one, or many can be beneficial as there are often times that making simultaneous readings will speed things up a lot (e.g. PSU efficiency testing).
    Best Regards,
    Rachael
    mcb1 over 9 years ago in reply to rachaelp
    Here's a good reference for Power Supplies.
    http://www.hammondmfg.com/pdf/5c007.pdf
    The DC voltage on the filter capacitor for your supply with the Bridge Rectifier is 120 x 1.414 = 169.68 volts give or take a little.
    Caution is a good idea.
    The others are giving great advice, so I'm sure you'll eventually work out what went and took out the fuse.
